When I play a video file on Windows Media Player, the background noises are much louder than the vocal noises. And when I convert the video for burning in TMPGenc, the same problem occurs.
The audio sounds fine when I play it on VLC player. How do I fix it on Windows Media Player, TMPGenc, etc.?
Thanks.
Oh, sorry.
The video is a Xvid Avi file. With AC3 audio. I downloaded this clip. -
AC3 filter allows you to play around with volume, DRC etc. Might be worth a look.
Read my blog here.
How to remove the Vocal from Karaoke video
By dduong in forum SubtitleReplies: 1Last Post: 26th Aug 2011, 13:38 -
Reverse AnalogX Vocal Remover?
By EmpireStrikesBack198 in forum AudioReplies: 13Last Post: 1st Feb 2011, 19:22 -
What do you call these kinds of vocal samples?
By takearushfan in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2010, 20:43 -
Louder sound via ffmpegX
By maruz in forum ffmpegX general discussionReplies: 2Last Post: 2nd Oct 2009, 05:05 -
VLC Not Playing Vocal Soundtrack
By Wanderlustus in forum Software PlayingReplies: 4Last Post: 13th Feb 2009, 07:24
