So now will all the new tech(HDTV) how are the wires ratred from best to worst picture quality? (1 being worst)
1.RCA
2. composite
3. s-video(?)
4. component
can anyone hlep me by filling in the rest?
Results 1 to 10 of 10
What We Do In Life, Echoes In Eternity....
Rough ordering (worst to best). Some equipment performs better with a different order.
1. Cable RF (when used to connect cable box to TV)
2. RCA (composite)
3. S-Video (Y/C)
4. Analog Component YPbPr (standard definition 480i)
5. Analog Component YPbPr (wideband 480p, 720p, 1080i)
6. DVI/HDMI
HDTV is limited to #5 and #6 plus IEEE-1394 for special purposes.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks edDV
What We Do In Life, Echoes In Eternity.... -
VGA is somewhere between 4 & 6 also:
http://www.techlore.com/article/10061 -
I just got told the other day to always use the RGB cable/connection over the composite, this was for HDTV but would presume it holds true for most things.
Yes, if your TV has Y, Pb, Pr (green blue red connectors), that is best way to connect your DVD player or cable box other than DVI/HDMI. That completely bypasses the distortions of NTSC or PAL.Originally Posted by Lenny_Nero
EDTV/HDTV also allows the Y,Pb,Pr connections to be progressive 480p and sometimes 720p.Recommends: Kiva.org - Loans that change lives.
RGB is not for HDTV.
You are probably mistaking Component for RGB.snappy phrase
I don't know what you're talking about. -
It's the manufacturer's fault. They color code the Y Pb Pr connections, using Green, Red, Blue! What a way to mess people up with conflicting associations. Why couldn't they use Black? (Y), Purple? (Pb), and Orange? (Pr). Kinda Like YIQ. Then at least they would be easily differentiated between Composite (usually Yellow), RGB, and Stereo Audio (Usually Red & White).
Scott -
And sometimes but not always orange for S/PDIF coax.
Originally Posted by Cornucopia
Yeah I agree,RGB came out first in the 1960's and component in the 1990's.Although both are analog,RGB splits the primary colors and component splits the luminance and chrominance:
http://en.wikipedia.org/wiki/Component_video
BTW..maybe Baldrick et al can make this thread a sticky?
Need Quality Type That I must choose
By cyberlion in forum EditingReplies: 37Last Post: 11th Jul 2010, 10:17 -
Start Tracks for new type of encrypted DVD's - Running list
By Groty in forum DVD RippingReplies: 8Last Post: 27th Dec 2009, 22:04 -
DVD Recorder - Quality Issues (NOT PC TYPE)
By jaffacaique in forum Video Streaming DownloadingReplies: 11Last Post: 1st Apr 2009, 16:45 -
Where can I find out how to connect all these wires?
By sarainelkins in forum AudioReplies: 1Last Post: 15th Apr 2008, 02:01 -
Wires in the wall
By ahhaa in forum ComputerReplies: 6Last Post: 12th Mar 2008, 13:13
