Results 1 to 10 of 10
  1. ive got 7 avi files i want to join and put on dvd can any 1 suggest a way to do this i want to put a chapter at the start ov each clip.thanks andy
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Encode each AVI separately to DVD specs mpg
    Author with TMPGenc DVD Author (all mpgs to the same title)
    /Mats
  3. You can used MS movie maker to join avi togather and change to mpeg all at the same time. The chapter point in MS movie maker is between avi clip, I not sure they will be preserve in DVD, because I do not think avi ( mostly 320x240 ) look good on TV.
    Can you post your viewing result and the size/type TV you used ?
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ? Neither AVI nor mpg (in fact, hardly any file format at all!) has chapter points - only DVD, VCD and SVCD do (disc formats).
    /Mats
  5. all i want is a avi to mpeg converter tjhen i can join them any ideas ive been looking for ages for 1 thanks andy
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If you have to join the AVIs, you can use VirtualDub: Load first AVI, then add the rest with Append video segment. But all AVIs must share the same specs with respect to audio/video type, resolution, bitrates & c. This is not a VirtualDub quirk - it's the way it works.
    But, since your goal is to create a video-DVD, again: There's no need to join the avis. Encode each AVI to dvd mpg specs, and author them together.
    /Mats
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You can ? Here I was thinking MS Movie Maker only output DV and WMV ?
    If in doubt, Google it.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by mats.hogberg
    You're never too old to learn, jimmalenko!
    /Mats
    Obviously !
    I'm thinking of Windows Movie maker though - maybe not the same product ?
