I'm trying to convert a video I made in Final Cut Pro. I export it in "final cut pro movie" (which if I understand right is a quicktime movie in dv video codec). Then I try to convert that file in ffmpeg with the VCD preset (I tried the two ones).
I always get this error when muxing (I think):
**ERROR: [mplex] Too many frame drops -exiting
It's weird because I already converted some of my video that way and it worked great. You can see that I' m really an amateur when it comes to converting and I don't understand much past the presets.![]()
(the zip is the log of the process and a screenshot of ffmpeg)
(edit: you can get the file here: www.erobote.com/error_ffmpeg.zip )
I tried it. I can't seem to be abble to convert my quicktime movie with it. The "convert" commands in the menu are gray. Anyone got another solution? Should I post this in another part of the forum?
Try using the Export commands. Perhaps it can be saved as something else. You might also try NOT exporting from FCP; instead, save it as a "reference movie". MPEG Streamclip can work with ref movies.
MPEG Streamclip does not make VCD-ready files. It doesnt create MPEG1 or 2 video at all.
.mov to .mp4 error
By ShadeChar in forum ffmpegX general discussionReplies: 7Last Post: 24th Apr 2012, 15:38 -
Converting MOV to MP2 mux error
By Compufix in forum ffmpegX general discussionReplies: 2Last Post: 30th Nov 2010, 00:38 -
Error encoding .mov to FLV
By stembridge in forum ffmpegX general discussionReplies: 7Last Post: 15th Sep 2009, 09:09 -
Error when converting to MOV, MP4, h.264
By marcoscabral in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2009, 13:00 -
MPEG1 SYNC error
By diginode in forum Authoring (DVD)Replies: 10Last Post: 1st Aug 2007, 23:09
