I have tried to convert these files..to avi with no luck..is there a way to play these asf files on my pc and to record them into a different file format?if so what program would one use?
Results 1 to 22 of 22
convert asf to anything with super 1
if you want to capture streaming asf read https://forum.videohelp.com/viewtopic.php?t=270338 -
Select AutoMode under output, select DVD and NTSC.
Or mpeg(mpeg2), 720x480 or 352x240 and 29.97frame/sec, 48000 audio. and add in your authoring tool. -
Virtualdub 1.3c should open ASF files and convert to AVI - however my experience has been that a lot of ASFs (particularly downloaded files) are brokn in some way, shape or form. In this case, ASFTools has generally been able to solve my problems.
If worst comes to worst, you could probably use an AVISynth script to get the file into virtualdub.If in doubt, Google it. -
Would it help to convert the asf files into something like a avi or mpeg3 then to a dvd compliant format..the end I am trying to get to is to write a dvd using the asf files..thank you for any help
You must have missed our exalted leader's post:
https://forum.videohelp.com/viewtopic.php?p=1460266#1460266
Tell SUPER to output NTSC and it should play on your DVD player.If in doubt, Google it. -
Originally Posted by scustalow
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 13:11 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:56 -
How to cut ASF file accurately ?
By mahogany in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2010, 11:31 -
help on .asf file conversion
By fabpozzi in forum Video ConversionReplies: 5Last Post: 23rd Jun 2008, 19:13 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 08:47
