I decided to buy some Convertor to transfer my old VHS cassets.
I think to buy Canopus ADVC 55. What you think about this model?
I dont see that this model hava audio-video lock.
I dont want to buy Canopus ADVC 110(money problem).
So, tell me your opinions and experience with Canopus ADVC 55.
How this Convertor work with Pinnacle Studio for Capture.
best regard
And very importan for me is How thic converter work with bad VHS cassete?
I have had that device.
It's one of the best device that i have bought. The most stable capturing. Also captures signals with macrovsion. The mainly problem is that it haven't proc amps controls (contrast , color , ....)
Another problem is the incompatibility with firewares card with the Via Chip.
And it works fine with the 99% video editor programs -
How that convertor work with very old VHS casette?
I think on dropped frames, addio video sync... -
I own that same unit, and love it. Also have a Hauppauge PVR-250. As far as how well it works on bad tapes, that depends on your VCR. If the tape is pretty bad, you need to use a TBC. Get a JVC VCR with digital noise reduction, and a built-in TBC. TBC makes a great deal of difference in dropped frames on anything. I did a test once with TBC and without on a rare tape that was in bad shape. With TBC, only dropped 2 frames in the first 2 minutes, without over 200 frames were dropped.
Canopus ADVC55 vs Roxio USB
By matt9b in forum Capturing and VCRReplies: 38Last Post: 25th Aug 2012, 19:23 -
A problem with ADVC55
By Mehedict in forum Capturing and VCRReplies: 2Last Post: 13th Sep 2008, 05:57 -
Canopus ADVC55 red light status indicator
By bobmccredie in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2008, 00:10 -
Hi8 to DV-AVI: Analog to Digital Passthrough or Canopus ADVC55?
By Ear Whiskers in forum Capturing and VCRReplies: 8Last Post: 8th Feb 2008, 22:23 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 03:56
