Is the resolution 220*164 a good resolution??
FPS == 25
I know I'm being a n00b, but which do you guyz consider to be the optimum (best) resolution quality??
Results 1 to 9 of 9
a good resolution for what? a portable/handheld device?
what video codec? -
for viewing a video file.. (AVI)
I dunno the codec.. can't be DivX certainly.. -
I think 7680 × 4320 is about the best resolution to date for video:
http://en.wikipedia.org/wiki/Ultra_High_Definition_Video
You might need some special equipment though. -
No matter what, 220*164 is no "standard" video resolution. Good possibly for some hand held device.
/Mats -
Yeah I figured it out..
sorry for the trouble guyz...
It turned out to be *crap* quality to watch on the comp.. Thx for your insight though..
MODS can lock this one now! -
Frame size is usually a matter of compromise. Generally, the bigger the frame the better the picture. But the bigger the file size too. In addition, you have other parameters to consider:
There's no point in using a really big frame if your source is very low resolution. You'll just get a big fuzzy picture.
When using lossy compression techniques like MPEG or Divx, it takes higher bitrates to encode higher resolution data. You usually need to find a balance between frame size and bitrate. This can vary with the source. A dark, low detail, low motion source will compress much better than a bright, high detail, high motion source. The former may look fine at 720x480, 30 fps, with 2000 kbps. The latter won't.
Playback devices have limitations. DVD players are limited 720x480 (NTSC, 720x576 PAL) at the highe end. So you can't use 1280x720. Even at 720x480 there are limits to the bitrate you can use. The iPod has a 320x240 display. There's no point in encoding at 1280x720, the iPod can't play that size. Even if it could play the file, the high resolution is huge waste of space for the small display. -
Indeed - and if you re-encode your video to the native resolution of a handheld you have other benefits:
1.The picture quality is often better (scaling on the fly can be a sod !).
2. Reduced bitrate = less disk access = longer battery life
3. less bitrate = more content on the disc !
I have an Archos AV400 and find most films play well at about 250Mb using DivX and a moderate, fixed bitrate MP3 for the audio (about 128kbps). For fast action stuff, I add about 50Mb to the allowed file size. For animated movies, deduct the same. I set my resolution width to be 320 pixels (native for my AV400) and on a display that size, it looks pretty good to me on those long flights or stays in departure halls.
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
DVDStyler query...
By mjl1297 in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 05:36 -
Vegas 8 query
By Fukushuu in forum EditingReplies: 6Last Post: 1st Feb 2009, 21:41 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
Resolution Query
By anirban in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2008, 02:48
