Hello!
When using ffmpegX to author a DVD from an mpeg and an .srt file, as I;ve frequently done in the past, I now get the followin g error message in the Progress Info window:
INFO: Locale=C
INFO: Converting filenames to US-ASCII
INFO: Detected subtitle file format: subviewer
INFO: Opened iconv descriptor. *UTF-8* *ISO-8859-1*
INFO: Read 749 subtitles
INFO: Adjusted 21 subtitle(s).
ERR: New_Face failed. Maybe the font path is wrong.
Please supply the text font file (Arial.ttf).
WARN: subtitle font: load_sub_face failed.
STAT: 0:01:20.140
The font is definitely there, in both my system library's font folder and my user library's font folder. There's no indication it's corrupted. Could there be a permissions problem? This never happened before I migrated old files from an old to a new machine.
Any advice on how to fix this? Thanks!
I had this error some time ago with an older version. It worked under the admin account I used to install ffmpegX, but it didn't work for a different, non-admin account, because some program parts had been installed into the admin home folder. Search for hidden folders there (starting with a .) that are not on the normal users's home folder. Also search for the arial.ttf with a program like FileBuddy when logged in as admin. That's how I found out about the hidden folders.
In the latest version however, it seems these folders are gone, so maybe a fresh install will solve the problem.
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 06:30 -
add SRT to VIDEO_TS
By exekutive in forum MacReplies: 8Last Post: 4th Jul 2011, 12:49 -
Combining Srt files into one for the purpose of authoring a DVD
By isobel in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2010, 06:48 -
ffmpegx, video_ts to .avi with mencoder, won't create .srt subtitles
By patrapao in forum MacReplies: 4Last Post: 14th May 2009, 19:36 -
subtitle timing when converted from srt to .sub (for DVD authoring)
By qknet in forum SubtitleReplies: 4Last Post: 10th Oct 2008, 04:22
