Hi!
I have a problem, im trying to burn Naruto episodes (avi) to DVD-RW so that I can watch them on my TV.
Everything works fine, except one thing - the Naruto episodes are 640x480 and when I watch them on my Widescreen TV the image is to high on the diagonal (the sub dont show). The width is fine, I get black borders on the sides couse it is recorded in 4:3 but other then that the width is fine. But I loose information in both the top and bottom of the image, worst of all I cant see the sub (actually, I can see half the sub, but the rest is outside of the picture-frame).
Do you know how I can make this work with the sub and all?
Results 1 to 17 of 17
Search the forums, as this is one of the most asked questions. Search for overscan and anime. In short, fansubbers put the subtitles in the wrong place. They are subbed for watching on a PC only, not a TV. To fix it you must add a border all around and shrink the image until the subs are visible. This means you have to process the video before encoding and authoring. Add FitCD to your search criteria and you will have answers galore
Read my blog here.
Er... I dont understand this at all...
I dont get a border, there is no options for that... Is it not possible to simply ad a border and save the file as a avi-file (identical to the source but with border) and then burn it with Nero?
Gah! This much work, Im beginning to think its not worth it...
Please tell me in a "new-bie" kind of way how to get this done. I would appreciate it!
It seems the black border does not shrink the picture, ist just like a layer over it and the black frame is above the sub... or something... help!
PLEASE wait a couple days before bumping/replying to your topic. this is no chat.
Ok, im sorry, its just so frustating when it doesnt work. Will not do it again.
Ok, so you know what the problem is - look at the picture below, the black frame is over the subtitle.
is the substitle permanent in the source file? or switchable/srt,sub file?
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 16:34 -
need help with HDConvertToX to make avi that is 1hr+ playable in DVD
By lett303 in forum Video ConversionReplies: 0Last Post: 6th Oct 2010, 15:30 -
Burning multiple remuxed folders to discs, playable as dvd
By blue2 in forum Authoring (DVD)Replies: 6Last Post: 8th Oct 2009, 10:05 -
Troubles burning avi to a dvd with nero vision
By falcon1 in forum Authoring (DVD)Replies: 3Last Post: 13th Oct 2008, 12:36 -
How do i convert .avi files to be playable on a dvd player?
By Beautiful Alone in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 05:03
