Everytime that i wanted to increase the volume or change an Ac3 audio file into a Wave file, i usually used Ac3Tool. Rip the Vob file using DVD Decrypter, then convert it to wave using Ac3Tool.
But an easier way is to open the Vob file into Sound Forge 7.0b, where you will see the video file at the top and the 2 Audio tracks underneath. Then if it's Ac3 audio, all you do is increase the volume and save as a Wave file, 48,000khz. This will just save the audio without the video. Then i just re-attach it back to the original Vob that i have put into TmpgEnc dvd Author. The new audio will be what you hear in the finished DVD. If you don't use TmpgEnc you can Multiplex it back with your original Video file.
If you have the AC3 plugin for Sound Forge you can output it back as AC3 instead of saving a wav file.
Read my blog here.
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 09:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 14:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
Removing Scratchiness with Sound Forge 8?
By solarblast in forum AudioReplies: 12Last Post: 17th Nov 2008, 11:30 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 01:33
