Hello,
I am using a program called XP Smoker Pro which has effectively sped up my computer. There is one tweak I would like to do but I don't know how. What I have done is use the "auto tuner" function which has worked great but one thing it does it block out the shortcut icons when you click on start (the area I am referring to is when you click start, it the area directly above "all programs" XP has the icons to the 4-5 commonly or most often used programs) I want to restore the ability for those icons. Hopefully this makes sense and somebody who uses this program can help me out, thanks!
They have their own forum over on their website so I'll try this question over there....
Blackmagic Intensity Pro Question
By wcwman18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 22nd Jul 2011, 16:45 -
Vegas Pro quick question
By ingeborgdot in forum EditingReplies: 7Last Post: 4th Oct 2010, 15:18 -
Vegas 8 pro question
By schematic2 in forum EditingReplies: 1Last Post: 14th Oct 2008, 21:44 -
Sony Vegas 8 Pro question
By ingeborgdot in forum EditingReplies: 4Last Post: 7th Sep 2008, 00:09 -
MainConcept MPEG Pro HD Question
By Nuke Shower in forum Video ConversionReplies: 3Last Post: 27th May 2008, 22:48
