Trying to backup "Collateral" as it's already got a slight scratch on it. However, it plays fine in the DVD player so I'm wondering why I can't get it ripped.
Tried the following:
DVD Shrink with and without AnyDVD - get the same error at 99% analysing: Failed to read drive D - without AnyDVD that's the only error I get. With AnyDVD I get that plus the "cyclic redundancy check".
DVD Decryptor - gets hung on the first VOB - I let it get up to 42 retries and said to heck with it. Did not use AnyDVD.
DVDFab - got stuck without AnyDVD - completed with AnyDVD BUT when I go to Shrink it says the 3rd VOB has "invalid data".
So, I've managed to get it ripped in file format but now I can't get it cut down to size to fit (it was a dual layer DVD).
Any suggestions?
More than likely your backup(the rip of it) has errors in it caused by reading through or skipping over the scratched portion of your disc. My suggestion would be that if you want a backup copy to find it in your local bargain bin or visit amazon.com and buy it for $10.99. Even if you manage to burn a disc your copy(backup) will more than likely not play correctly.
How do you backup your o/s?
By johns0 in forum PollsReplies: 23Last Post: 6th Apr 2011, 05:31 -
Backup Program
By HotDamn! in forum ComputerReplies: 7Last Post: 9th Mar 2010, 23:36 -
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 08:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 00:50 -
backup software
By alintatoc in forum ComputerReplies: 21Last Post: 25th Mar 2009, 13:23
