I've been encoding some .dv files for my iPod using both the Export to iPod setting in QTPro (7.0.4) and the iPod h.264 preset in ffmpegX. I'm seeing that the file produced by ffmpegX is darker than the one produced by QTPro, with the QTPro version most closely matching the original .dv file.
Is there any settings I should be using within ffmpegX to make the resulting file lighter, or anything I can do using QTPro afterwards? I'd prefer to use ffmpegX instead of QTPro for the h.264 encoding because it's faster and because it produces a file of the same quality (I set the bitrate to 500 and the Q settings on the options tab to 5 and 35) that is smaller. Thanks.
Workaround (maybe?): Alter the .dv file in iMovie with a filter to lower the contrast. Based upon what I'm seeing in my web browser (of what you posted), it appears that the compression of H264 is changing the gamma.
Using the .MOV mpeg-4 preset results in a movie that matches the original movie very well...much better than the iPod h.264 preset. The downside with the .MOV mpeg-4 method is that I have to save my file out of Final Cut Express as a .dv or else it can't be encoded (some problem with .dv in a QuickTime movie that is in a file format other than .dv).
Not a big deal, I suppose, but a nuisance if I happen to export out of FCE as a FCE format movie rather than a .dv format using the QuickTime export function.
[Help Request] Sony Vegas 10 Pro, AVC/H.264 Encoding
By lindenkron in forum Newbie / General discussionsReplies: 91Last Post: 8th Jul 2011, 04:14 -
VIDEO_TS to iPod H.264 and subtitles
By veravera in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 16:39 -
Ipod - h.264 or MPEG-4, which one is better?
By FallenAngelII in forum DVD RippingReplies: 1Last Post: 10th Jan 2008, 12:12 -
converting to h.264 for ipod
By nagihcim1 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 09:27 -
Flash videos look darker after encoding
By DVinci in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 01:35
