Hi,
I usually work using a Sony DSR-390.
For the camera, I use the following Battery and Lighting equipment:
Battery - Sony BP-M100
Lighting equipment (attached to the camera, and runs off the Battery) - Anton Bauer Ultralight 2
When I use my Sony PD-170, the lighting equipment gets its power from a Bescor Battery Belt. In turn, the camera's batteries don't drain as quickly (1 can run for over 500 minutes.)
On the other hand, since the lighting equipment on my Sony DSR-390 gets its power from the Camera's battery, the battery drains very quickly and needs to be changed regularly (Which usually turns into a missing clip during the editing process.)
Thus, I was wondering if a camera belt is available for the Anton Bauer Ultralight 2. Or, since I have two battery belts for my Sony PD-170, if an adapter is available to attach my lighting equipment to them?
Thank You,
Stanley Sandler
Results 1 to 1 of 1
Cheap chinese batteries fault or my charger ?!
By JoseD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 6th Oct 2008, 18:23 -
Cordless phone batteries.
By Poppa_Meth in forum Off topicReplies: 2Last Post: 22nd Nov 2007, 09:51 -
Camcorder batteries
By Delerious in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 23rd Sep 2007, 14:29 -
usb rechargeable batteries
By yoda313 in forum Off topicReplies: 0Last Post: 29th May 2007, 20:43 -
Rechargeable batteries?
By Lucifers_Ghost in forum Off topicReplies: 11Last Post: 24th May 2007, 17:54
