Opening an audio mp3 file and encoding it to mp2 I find some problems, first I deselect the video deconding option, then I choose the mp2 format and I select encoding... ffmpegx spent 1 sec to encode, but only seems to encode, and I get a mp2 file that doesn't work...
is it possible to encode only an mp3 file?
Results 1 to 9 of 9
it doesn't work and I don't understand why:
I post the log:
I don't know why I select imput stream 0 and it finds imput stream 0.1Code:Encoding started on Sun Feb 5 16:08:05 CET 2006 Mac OSX static build for ffmpegX Input #0, mp3, from '/Users/matteomatteo/Desktop/dvd oc/codifica/The.Oc.-.2x08.-.La.forza.dell'amore.-.[00257107].mp3': Duration: 00:38:17.1, start: 0.000000, bitrate: 159 kb/s Stream #0.0: Audio: mp3, 48000 Hz, stereo, 160 kb/s Could not find input stream #0.1
No way, it's the same also like this:
it's a bug maybe?Code:Encoding started on Sun Feb 5 17:44:20 CET 2006 Mac OSX static build for ffmpegX Input #0, mp3, from '/Users/matteomatteo/Desktop/dvd oc/codifica/7.mp3': Duration: 00:40:10.2, start: 0.000000, bitrate: 159 kb/s Stream #0.0: Audio: mp3, 48000 Hz, stereo, 160 kb/s Could not find input stream #0.1
now it's working thanks you a lot, but maybe I found a bug...
first of all in the menu there is no "audio file to mp2" because there are to "audio file to mp3" (but if u select the first appears mp2 so I thinks it's only a type error) take a look:
but also choosing the first and getting the mp2 encoding doesn't work, I had to select the second "audio file to mp3" and than changing in the audio tab mp3 with mp2 it work...
I hope it can be usefull for someoe else...
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 16:50 -
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 03:01 -
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 05:11 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 01:46 -
How to convert .ts file with mp3 audio encoding into an MP4
By gauche in forum Video ConversionReplies: 6Last Post: 8th Nov 2008, 16:38
