Results 1 to 27 of 27
  1. I am sorry for the repost...I posted this question recently but cannot find it, even searching by the author
    I just finished making subtitles for 9 minutes of mpg file with subtitle creator. They are in a .sub file now. What software do I need to use to take the mpg file, add the subtitles to it and create a DVD? What is this process called? I have looked at several softwares and they all seem to need a avi file to start with
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    .sub as in text file, or .sub as in .sub/.idx?
    If the former, convert to .srt, then to .sup with srt2sup
    If the latter convert to .sup with sub2sup
    Author with IfoEdit (or other authoring app that supports .sup subtitles)
    /Mats
    just click on subtitle creator and you will see what tools you can author to a dvd with...
    you can also author with dvdauthorgui, muxman,dvd-lab pro, ulead dvd workshop...they all support subs, most text subs then.
  4. Thanks! I have the text subtitle file modified but I am having a problem getting the video file to be accepted by almost any of the freebies mentioned in the last posting. The video file was created by TPMGEnc I think it is an MPG file but I get different kinds of error messages depending on which program I am using. DVDAuthorGUI error message says that "NAV packets are not found in the file". Muxman just refused to recognize it period, won't open it. So close...but yet so far!
  5. Demultiplex your mpg file (projectx, tmpgenc mpeg tools...) and use the elementary video and audio streams with the 'freebies'
  6. Hi,
    I have all the files separated now and put them back together with muxman and DVDauthorgui. They both run flawlessly but neither produces results with subtitles. I am using powerdvd to view the results. I have read the text files produced as the programs work and see no errors. I have redone it several times. Any suggestions?
  7. I don't know PowerDVD very well, but usually the subtitles do not show up automatically. You have to select them. In WinDVD you would need to click on the 'movie' during playback with the right mouse button and select 'Subtitles' and activate 'Subtitle 1' or 'Subtitle 2' or...
    By default subtitles are deactivated...
  8. Thanks! I have looked at the menu option to display subtitles but it is not an option - it is grayed out - using 2 different dvd players.
    I know there is potentially one problem. When I was preparing the video file I used tmpgenc and made the video file fit only 60% of the screen. The rest of the screen is black, and I know the subtitles are also black. So, I think now I have 2 problems.
    1. The subtitles do not seem to be there. I remuxed the files and put the subtitles in the center of the screen (where they would be right on top of the audio and should show up)- they still do not show up.
    2. Even if they were there the text is black and they are showing on a black background. They would be invisible!
    Help!
  9. The 'color problem' can be solved easily with DVDSubEdit
    But if the subs are not in the vobs, we need a little bit more info...
    1. In which format do you have the subtitels now? (if unsure, post some lines)
    2. Which progran did you use for multiplexing (authoring) the vob files?
    3. It would be helpful (for me) if you would use (my) GUI for dvdauthor or dvdauthorgui for authoring and post the log file somewhere...
  10. Are you sure you demuxed the audio and video, had DVDauthorGui load the video, (audio loads automatically if same name), then specified the subtitle file and created the DVD?
    I am confused by your statement of "putting them back together". You do not do that. The prog requires two, or with subtitles three, seperate files which are seperately specified, except as noted with audio.
    Also confused by you putting the subtitles right on top of the Audio? Assuming you meant Video?
    To answer another question, the subtitles are NOT part of the MPG file. They are played together when placed on a properly authored DVD. It is the authoring stage where the subtitles are placed on the DVD as an option.
    Great prog Borax, BTW. But referencing paragraph 2 above, why not auto-load a subtitle file with the same name as video? And put an egg in my beer while you're at it.
  11. Thanks! I have been "playing with" multimedia for the past year or so but have never had the pleasure of doing the same thing twice
    To prepare the video file I used TMPGEnc and limited the video to 60% of the screen (the original source was a VCD). I now have a file called interviewv (v for video) and interviews (s for sound) and interview srt format.srt for the subtitles. I have used both muxman and dvdauthorgui to mux them. In both cases I had no subtitles I even tried placing the subtitles in the middle of the screen to eliminate the problem of black print on a black background but still got no subtitles.
    Below is a listing of the log of dvdauthorgui:
    DVDAuthorGUI 1.008b - 1/14/2006
    Send problems with DVDAuthorGUI to liquid_217@hotmail.com
    ***please wait while the titles are multiplexed.
    *multiplexing title: 1.....
    INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    INFO: [???] File C:\Documents and Settings\Tom\Desktop\Interview Final\INTERVIEW1v.m2v looks like an MPEG Video stream.
    INFO: [???] File C:\Documents and Settings\Tom\Desktop\Interview Final\INTERVIEW1s.mp2 looks like an MPEG Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Tom\Desktop\Interview Final\INTERVIEW1v.m2v)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width : 720
    INFO: [???] Frame height : 480
    INFO: [???] Aspect ratio : 16:9 display
    INFO: [???] Picture rate : 29.970 frames/sec
    INFO: [???] Bit rate : 9000000 bits/sec
    INFO: [???] Vbv buffer size : 229376 bytes
    INFO: [???] CSPF : 0
    INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\Tom\Desktop\Interview Final\INTERVIEW1s.mp2)
    INFO: [???] MPEG AUDIO STREAM: c0
    INFO: [???] Audio version : 1.0
    INFO: [???] Layer : 2
    INFO: [???] CRC checksums : no
    INFO: [???] Bit rate : 49152 bytes/sec (384 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] Mode : 0 stereo
    INFO: [???] Mode extension : 0
    INFO: [???] Copyright bit : 0 no copyright
    INFO: [???] Original/Copy : 0 copy
    INFO: [???] Emphasis : 0 none
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 9587000
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [???] Scanned to end AU 17408
    INFO: [???] STREAM e0 completed @ frame 17408.
    INFO: [???] STREAM c0 completed @ frame 24202.
    INFO: [???] Multiplex completion at SCR=52286025.
    INFO: [???] Video e0: buf= 180786 frame=017408 sector=00287273
    INFO: [???] Audio c0: buf= 640 frame=024202 sector=00013803
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length: 580822056 bytes
    INFO: [???] Sequence headers: 1092
    INFO: [???] Sequence ends : 1
    INFO: [???] No. Pictures : 17408
    INFO: [???] No. Groups : 1092
    INFO: [???] No. I Frames : 1092 avg. size 72683 bytes
    INFO: [???] No. P Frames : 5442 avg. size 46023 bytes
    INFO: [???] No. B Frames : 10875 avg. size 23079 bytes
    INFO: [???] Average bit-rate : 7998800 bits/sec
    INFO: [???] Peak bit-rate : 10294800 bits/sec
    INFO: [???] BUFFERING min 15 Buf max 156084
    INFO: [???] AUDIO_STATISTICS: c0
    INFO: [???] Audio stream length 27881856 bytes.
    INFO: [???] Syncwords : 24203
    INFO: [???] Frames : 24203 padded
    INFO: [???] Frames : 0 unpadded
    INFO: [???] BUFFERING min 15 Buf max 1163
    INFO: [???] MUX STATUS: no under-runs detected.
    *processing subtitles for title: 1 sub 1...
    DVDAuthor:pumux, version 0.6.12-alpha-2907.
    Build options: gnugetopt iconv freetype
    Send bugs to <dvdauthor-users@lists.sourceforge.net>
    INFO: Locale=C
    INFO: Converting filenames to US-ASCII
    INFO: Detected subtitle file format: subviewer
    INFO: Opened iconv descriptor. *UTF-8* *ISO-8859-1*
    INFO: Read 195 subtitles
    INFO: Adjusted 78 subtitle(s).
    INFO: Unicode font: 1185 glyphs.
    STAT: 0:00:17.000
    STAT: 0:00:21.178
    STAT: 0:00:23.178
    STAT: 0:00:25.178
    STAT: 0:00:29.178
    STAT: 0:00:34.178
    STAT: 0:00:36.178
    STAT: 0:00:41.178
    STAT: 0:00:43.178
    STAT: 0:00:49.178
    STAT: 0:00:55.178
    STAT: 0:00:58.178
    STAT: 0:01:03.178
    STAT: 0:01:05.178
    STAT: 0:01:08.178
    STAT: 0:01:10.178
    STAT: 0:01:16.178
    STAT: 0:01:20.178
    STAT: 0:01:22.178
    STAT: 0:01:25.178
    STAT: 0:01:31.178
    STAT: 0:01:34.178
    STAT: 0:01:37.178
    STAT: 0:01:39.178
    STAT: 0:01:41.178
    STAT: 0:01:47.178
    STAT: 0:01:49.178
    STAT: 0:01:52.178
    STAT: 0:01:56.178
    STAT: 0:01:58.178
    STAT: 0:02:03.178
    STAT: 0:02:05.178
    STAT: 0:02:07.178
    STAT: 0:02:11.178
    STAT: 0:02:15.178
    STAT: 0:02:17.178
    STAT: 0:02:18.178
    STAT: 0:02:21.178
    STAT: 0:02:25.178
    STAT: 0:02:28.178
    STAT: 0:02:29.178
    STAT: 0:02:31.178
    STAT: 0:02:35.178
    STAT: 0:02:37.178
    STAT: 0:02:41.178
    STAT: 0:02:43.178
    STAT: 0:02:46.178
    STAT: 0:02:48.178
    STAT: 0:02:50.178
    STAT: 0:02:54.178
    STAT: 0:02:57.178
    STAT: 0:02:59.178
    STAT: 0:03:03.178
    STAT: 0:03:05.178
    STAT: 0:03:07.178
    STAT: 0:03:12.178
    STAT: 0:03:15.178
    STAT: 0:03:16.178
    STAT: 0:03:18.178
    STAT: 0:03:22.178
    STAT: 0:03:26.178
    STAT: 0:03:29.178
    STAT: 0:03:31.178
    STAT: 0:03:33.178
    STAT: 0:03:34.178
    STAT: 0:03:36.178
    STAT: 0:03:38.178
    STAT: 0:03:40.178
    STAT: 0:03:42.178
    STAT: 0:03:45.178
    STAT: 0:03:48.178
    STAT: 0:03:51.178
    STAT: 0:03:55.178
    STAT: 0:03:59.178
    STAT: 0:04:02.178
    STAT: 0:04:06.178
    STAT: 0:04:08.178
    STAT: 0:04:10.178
    STAT: 0:04:12.178
    STAT: 0:04:13.178
    STAT: 0:04:18.178
    STAT: 0:04:21.178
    STAT: 0:04:23.178
    STAT: 0:04:24.178
    STAT: 0:04:26.178
    STAT: 0:04:29.178
    STAT: 0:04:32.178
    STAT: 0:04:34.178
    STAT: 0:04:36.178
    STAT: 0:04:38.178
    STAT: 0:04:39.178
    STAT: 0:04:41.178
    STAT: 0:04:42.178
    STAT: 0:04:44.178
    STAT: 0:04:46.178
    STAT: 0:04:47.178
    STAT: 0:04:48.178
    STAT: 0:04:51.178
    STAT: 0:04:53.178
    STAT: 0:04:55.178
    STAT: 0:04:57.178
    STAT: 0:04:58.178
    STAT: 0:05:03.178
    STAT: 0:05:08.178
    STAT: 0:05:11.178
    STAT: 0:05:13.178
    STAT: 0:05:15.178
    STAT: 0:05:16.178
    STAT: 0:05:19.178
    STAT: 0:05:22.178
    STAT: 0:05:24.178
    STAT: 0:05:26.178
    STAT: 0:05:29.178
    STAT: 0:05:30.178
    STAT: 0:05:33.178
    STAT: 0:05:34.178
    STAT: 0:05:38.178
    STAT: 0:05:42.178
    STAT: 0:05:43.178
    STAT: 0:05:45.178
    STAT: 0:05:48.178
    STAT: 0:05:52.178
    STAT: 0:05:55.178
    STAT: 0:06:00.178
    STAT: 0:06:02.178
    STAT: 0:06:05.178
    STAT: 0:06:08.178
    STAT: 0:06:11.178
    STAT: 0:06:13.178
    STAT: 0:06:16.178
    STAT: 0:06:20.178
    STAT: 0:06:22.178
    STAT: 0:06:26.178
    STAT: 0:06:33.178
    STAT: 0:06:37.178
    STAT: 0:06:41.178
    STAT: 0:06:43.178
    STAT: 0:06:45.178
    STAT: 0:06:47.178
    STAT: 0:06:48.178
    STAT: 0:06:50.178
    STAT: 0:06:54.178
    STAT: 0:06:56.178
    STAT: 0:06:58.178
    STAT: 0:07:03.178
    STAT: 0:07:07.178
    STAT: 0:07:10.178
    STAT: 0:07:12.178
    STAT: 0:07:15.178
    STAT: 0:07:18.178
    STAT: 0:07:20.178
    STAT: 0:07:22.178
    STAT: 0:07:32.178
    STAT: 0:07:37.178
    STAT: 0:07:42.178
    STAT: 0:07:48.178
    STAT: 0:07:53.178
    STAT: 0:07:57.178
    STAT: 0:08:01.178
    STAT: 0:08:05.178
    STAT: 0:08:08.178
    STAT: 0:08:09.178
    STAT: 0:08:11.178
    STAT: 0:08:12.178
    STAT: 0:08:13.178
    STAT: 0:08:16.178
    STAT: 0:08:18.178
    STAT: 0:08:21.178
    STAT: 0:08:28.178
    STAT: 0:08:33.178
    STAT: 0:08:35.178
    STAT: 0:08:38.178
    STAT: 0:08:41.178
    STAT: 0:08:43.178
    STAT: 0:08:48.178
    STAT: 0:08:50.178
    STAT: 0:08:56.178
    STAT: 0:08:58.178
    STAT: 0:09:01.178
    STAT: 0:09:03.178
    STAT: 0:09:06.178
    STAT: 0:09:09.178
    STAT: 0:09:10.178
    STAT: 0:09:12.178
    STAT: 0:09:15.178
    STAT: 0:09:17.178
    STAT: 0:09:19.178
    STAT: 0:09:22.178
    STAT: 0:09:24.178
    STAT: 0:09:26.178
    STAT: 0:09:29.178
    STAT: 0:09:32.178
    STAT: 0:09:33.178
    INFO: Found EOF in .sub file.
    WARN: Read 0, expected 4
    INFO: 193 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
    Statistics:
    - Processed 193 subtitles.
    - The longest display line had 56 characters.
    - The maximum number of displayed lines was 2.
    - The normal display height of the font arial.ttf was 32.
    - The bottom display height of the font arial.ttf was 45.
    - The biggest subtitle box had 2886 bytes.
    erase "C:\Documents and Settings\Tom\Desktop\Interview Final\CCTV7 Interview\cctv7\cctv7\presub.mpg"
    echo *authoring title(s).....
    "C:\Program Files\DVDAuthorGUI\bin\dvdauthor.exe" -x "C:\Program Files\DVDAuthorGUI\config.xml"
    DVDAuthor::dvdauthor, version 0.6.12-alpha-2907.
    INFO: Locale=C
    INFO: dvdauthor creating VTS
    STAT: Picking VTS 01
    STAT: Processing C:\Documents and Settings\Tom\Desktop\Interview Final\CCTV7 Interview\cctv7\cctv7\title1.mpg...
    STAT: VOBU 16 at 7MB, 1 PGCS
    STAT: VOBU 32 at 15MB, 1 PGCS
    STAT: VOBU 48 at 23MB, 1 PGCS
    STAT: VOBU 64 at 32MB, 1 PGCS
    STAT: VOBU 80 at 41MB, 1 PGCS
    STAT: VOBU 96 at 49MB, 1 PGCS
    STAT: VOBU 112 at 58MB, 1 PGCS
    STAT: VOBU 128 at 67MB, 1 PGCS
    STAT: VOBU 144 at 75MB, 1 PGCS
    STAT: VOBU 160 at 84MB, 1 PGCS
    STAT: VOBU 176 at 93MB, 1 PGCS
    STAT: VOBU 192 at 101MB, 1 PGCS
    STAT: VOBU 208 at 110MB, 1 PGCS
    STAT: VOBU 224 at 119MB, 1 PGCS
    STAT: VOBU 240 at 127MB, 1 PGCS
    STAT: VOBU 256 at 136MB, 1 PGCS
    STAT: VOBU 272 at 145MB, 1 PGCS
    STAT: VOBU 288 at 154MB, 1 PGCS
    STAT: VOBU 304 at 162MB, 1 PGCS
    STAT: VOBU 320 at 171MB, 1 PGCS
    STAT: VOBU 336 at 180MB, 1 PGCS
    STAT: VOBU 352 at 188MB, 1 PGCS
    STAT: VOBU 368 at 197MB, 1 PGCS
    STAT: VOBU 384 at 206MB, 1 PGCS
    STAT: VOBU 400 at 214MB, 1 PGCS
    STAT: VOBU 416 at 223MB, 1 PGCS
    STAT: VOBU 432 at 232MB, 1 PGCS
    STAT: VOBU 448 at 240MB, 1 PGCS
    STAT: VOBU 464 at 249MB, 1 PGCS
    STAT: VOBU 480 at 258MB, 1 PGCS
    STAT: VOBU 496 at 266MB, 1 PGCS
    STAT: VOBU 512 at 275MB, 1 PGCS
    STAT: VOBU 528 at 284MB, 1 PGCS
    STAT: VOBU 544 at 293MB, 1 PGCS
    STAT: VOBU 560 at 301MB, 1 PGCS
    STAT: VOBU 576 at 310MB, 1 PGCS
    STAT: VOBU 592 at 319MB, 1 PGCS
    STAT: VOBU 608 at 327MB, 1 PGCS
    STAT: VOBU 624 at 336MB, 1 PGCS
    STAT: VOBU 640 at 345MB, 1 PGCS
    STAT: VOBU 656 at 353MB, 1 PGCS
    STAT: VOBU 672 at 362MB, 1 PGCS
    STAT: VOBU 688 at 371MB, 1 PGCS
    STAT: VOBU 704 at 379MB, 1 PGCS
    STAT: VOBU 720 at 388MB, 1 PGCS
    STAT: VOBU 736 at 397MB, 1 PGCS
    STAT: VOBU 752 at 405MB, 1 PGCS
    STAT: VOBU 768 at 414MB, 1 PGCS
    STAT: VOBU 784 at 423MB, 1 PGCS
    STAT: VOBU 800 at 431MB, 1 PGCS
    STAT: VOBU 816 at 440MB, 1 PGCS
    STAT: VOBU 832 at 449MB, 1 PGCS
    STAT: VOBU 848 at 457MB, 1 PGCS
    STAT: VOBU 864 at 466MB, 1 PGCS
    STAT: VOBU 880 at 475MB, 1 PGCS
    STAT: VOBU 896 at 483MB, 1 PGCS
    STAT: VOBU 912 at 492MB, 1 PGCS
    STAT: VOBU 928 at 501MB, 1 PGCS
    STAT: VOBU 944 at 509MB, 1 PGCS
    STAT: VOBU 960 at 518MB, 1 PGCS
    STAT: VOBU 976 at 527MB, 1 PGCS
    STAT: VOBU 992 at 535MB, 1 PGCS
    STAT: VOBU 1008 at 544MB, 1 PGCS
    STAT: VOBU 1024 at 553MB, 1 PGCS
    STAT: VOBU 1040 at 561MB, 1 PGCS
    STAT: VOBU 1056 at 570MB, 1 PGCS
    STAT: VOBU 1072 at 579MB, 1 PGCS
    STAT: VOBU 1088 at 588MB, 1 PGCS
    INFO: Video pts = 0.178 .. 581.058
    INFO: Audio[8] pts = 0.178 .. 581.050
    INFO: Audio[32] pts = 17.178 .. 583.179
    STAT: VOBU 1092 at 590MB, 1 PGCS
    INFO: Generating VTS with the following video attributes:
    INFO: MPEG version: mpeg2
    INFO: TV standard: ntsc
    INFO: Aspect ratio: 16:9
    INFO: Resolution: 720x480
    INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
    STAT: fixing VOBU at 7MB (17/1092, 1%)
    STAT: fixing VOBU at 15MB (33/1092, 2%)
    STAT: fixing VOBU at 23MB (49/1092, 4%)
    STAT: fixing VOBU at 32MB (65/1092, 5%)
    STAT: fixing VOBU at 41MB (81/1092, 7%)
    STAT: fixing VOBU at 49MB (97/1092, 8%)
    STAT: fixing VOBU at 58MB (113/1092, 10%)
    STAT: fixing VOBU at 67MB (129/1092, 11%)
    STAT: fixing VOBU at 75MB (145/1092, 13%)
    STAT: fixing VOBU at 84MB (161/1092, 14%)
    STAT: fixing VOBU at 93MB (177/1092, 16%)
    STAT: fixing VOBU at 101MB (193/1092, 17%)
    STAT: fixing VOBU at 110MB (209/1092, 19%)
    STAT: fixing VOBU at 119MB (225/1092, 20%)
    STAT: fixing VOBU at 127MB (241/1092, 21%)
    STAT: fixing VOBU at 136MB (257/1092, 23%)
    STAT: fixing VOBU at 145MB (273/1092, 24%)
    STAT: fixing VOBU at 154MB (289/1092, 26%)
    STAT: fixing VOBU at 162MB (305/1092, 27%)
    STAT: fixing VOBU at 171MB (321/1092, 29%)
    STAT: fixing VOBU at 180MB (337/1092, 30%)
    STAT: fixing VOBU at 188MB (353/1092, 32%)
    STAT: fixing VOBU at 197MB (369/1092, 33%)
    STAT: fixing VOBU at 206MB (385/1092, 35%)
    STAT: fixing VOBU at 214MB (401/1092, 36%)
    STAT: fixing VOBU at 223MB (417/1092, 38%)
    STAT: fixing VOBU at 232MB (433/1092, 39%)
    STAT: fixing VOBU at 240MB (449/1092, 41%)
    STAT: fixing VOBU at 249MB (465/1092, 42%)
    STAT: fixing VOBU at 258MB (481/1092, 43%)
    STAT: fixing VOBU at 266MB (497/1092, 45%)
    STAT: fixing VOBU at 275MB (513/1092, 46%)
    STAT: fixing VOBU at 284MB (529/1092, 48%)
    STAT: fixing VOBU at 293MB (545/1092, 49%)
    STAT: fixing VOBU at 301MB (561/1092, 51%)
    STAT: fixing VOBU at 310MB (577/1092, 52%)
    STAT: fixing VOBU at 319MB (593/1092, 54%)
    STAT: fixing VOBU at 327MB (609/1092, 55%)
    STAT: fixing VOBU at 336MB (625/1092, 57%)
    STAT: fixing VOBU at 345MB (641/1092, 58%)
    STAT: fixing VOBU at 353MB (657/1092, 60%)
    STAT: fixing VOBU at 362MB (673/1092, 61%)
    STAT: fixing VOBU at 371MB (689/1092, 63%)
    STAT: fixing VOBU at 379MB (705/1092, 64%)
    STAT: fixing VOBU at 388MB (721/1092, 65%)
    STAT: fixing VOBU at 397MB (737/1092, 67%)
    STAT: fixing VOBU at 405MB (753/1092, 68%)
    STAT: fixing VOBU at 414MB (769/1092, 70%)
    STAT: fixing VOBU at 423MB (785/1092, 71%)
    STAT: fixing VOBU at 431MB (801/1092, 73%)
    STAT: fixing VOBU at 440MB (817/1092, 74%)
    STAT: fixing VOBU at 449MB (833/1092, 76%)
    STAT: fixing VOBU at 457MB (849/1092, 77%)
    STAT: fixing VOBU at 466MB (865/1092, 79%)
    STAT: fixing VOBU at 475MB (881/1092, 80%)
    STAT: fixing VOBU at 483MB (897/1092, 82%)
    STAT: fixing VOBU at 492MB (913/1092, 83%)
    STAT: fixing VOBU at 501MB (929/1092, 84%)
    STAT: fixing VOBU at 509MB (945/1092, 86%)
    STAT: fixing VOBU at 518MB (961/1092, 87%)
    STAT: fixing VOBU at 527MB (977/1092, 89%)
    STAT: fixing VOBU at 535MB (993/1092, 90%)
    STAT: fixing VOBU at 544MB (1009/1092, 92%)
    STAT: fixing VOBU at 553MB (1025/1092, 93%)
    STAT: fixing VOBU at 561MB (1041/1092, 95%)
    STAT: fixing VOBU at 570MB (1057/1092, 96%)
    STAT: fixing VOBU at 579MB (1073/1092, 98%)
    STAT: fixing VOBU at 588MB (1089/1092, 99%)
    STAT: fixed 1092 VOBUS
    INFO: dvdauthor creating table of contents
    INFO: Scanning C:\Documents and Settings\Tom\Desktop\Interview Final\CCTV7 Interview\cctv7\cctv7/VIDEO_TS/VTS_01_0.IFO
    erase "C:\Documents and Settings\Tom\Desktop\Interview Final\CCTV7 Interview\cctv7\cctv7\*.mpg"
    echo *process complete
    *process complete
    I must say, the tools that I am working with seem to be very well designed - I am impressed with them. Now...to become knowledgeable enough to use them properly....
  12. If you load the file in Subtitle Workshop, it will auto-load the video (you will have to rename the file to the same name prefix) and this will allow you to preview the video with subs. Can change colors, also.
    The log file looks basically correct, by that I mean no errors and a valid subtitle file were found.
    Have you tried burning an RW disk and testing in a standalone player? It is possible the software is not recognizing the subs, though unlikely.
    Nov 2005
    As mats.hogberg posted, the format of the subs, whether graphical or text is important. Some DVD authoring programs, like muxman, will only accept the rendered (graphical .sup) subs. Some like DVDA use text only. As Baldrick posted, subtitle creator can handle it, render the subs to the sup format muxman (& AFAIK DVD Author GUI) requires. You don't have the option to display subs in PowerDVD because the DVD rightly tells the player it doesn't contain any.
  14. DVDauthor will accept SRT format subtitles, I have made several.
    Do the preview in subtitle workshop and post results.
  15. Thanks! Eureka! When I preview the project using subtitle workshop I have subtitles! They are white, displayed down on the bottom of the black area where I requested them to be. The only problem is that the video is has a strong blueish green tint, something that was not in the video before when I was using subtitle workshop to place the titles.
    When I burn the files to a dvd I have been under the impression that all I have to do is include the audio ts and video ts folders. Do I have to first copy the subtitle file to the video ts file?
    Close...very close.....but I still can't get a disk burnt with subtitles...
  16. As I mentioned previously, you must specifically identify the subtitle file in the DVD authoring program. It is not included nor is it part of any of the other files or sections of the video. It is built-in by the authoring program, but ONLY if you tell the authoring prog what subtitle file to use.
  17. Just remembered your log does show a subtitle file included, in SUB format. There is one warning at the end, the meaning of which I do not know. Try the SRT format, Workshop will convert, this has always worked for me. Try this on a standalone player and make sure to turn subtitles on.
  18. Member
    Nov 2005
    If it helps...
    "DVDauthor will accept SRT format subtitles"
    Nelson37 is correct, looking it up DVDAuthor uses spumux to handle them.
    https://www.videohelp.com/~liquid217/dlfiles85/readme.html
    http://dvdauthor.sourceforge.net/doc/spumux.html
    Might provide some hints -- according to the bottom linked page: "If processing textbased subtitles no other streams can be defined" Docs for both the GUI & main prog. talk about limited sub features -- don't know if any apply to your project.
    If all else fails, create sup files & use muxman, ifoedit etc...?
  19. Clarify - I thought you were asking about authoring, not burning. Once the file is authored, then yes, it IS included in the TS directory structure, not really sure where. There is no extra step required, just burn the directories as usual.
    On the Workshop preview, white may be the default color, try a color change and see if it shows up in preview. You may still have the black subtitles which are there but invisible.
  20. it IS included in the TS directory structure, not really sure where.
    Within the vob files. Subtitles are multiplexed within the mpeg (vob) just like video and audio streams.
    The log from dvdauthorgui looks absolutely correct. The warning: ' WARN: Read 0, expected 4' is normal for 'usual' subs, more are usually only used for menus.
    To do some error tracking, try to view your final result (DVD folder) with another soft player (VLC or MPC are great to check subs).
  21. Yikes! I am now in the situation where I can use the subtitle workshop and watch the video and see the subtitles but still, after muxing, cannot see the subtitles.
    Is there any muxing software that I can use that will allow me to directly use the file from subtitle workshop without having to use the srt2sup? There are sooooo many options and settings in these programs. I would like to be able to remove one step to see if that will help.
    This is the first time I have used muxman, DVDAuthorGUI and subtitle workshop. When I installed the programs I did not install any other filters. Do I need to?
    Sooooooooo close...but yet sooooo faaaaaaaarrrrr .....
  22. There is NO NEED to convert the SRT file for DVDAuthorGUI. It will accept the SRT file. That is one process you can eliminate.
    Wild guess - bitrate is near the maximum allowed. Try perhaps a short test file with a lower bitrate?
    Have you tried playback on a standalone DVD player?
  23. Originally Posted by Haopengyou
    Yikes! I am now in the situation where I can use the subtitle workshop and watch the video and see the subtitles but still, after muxing, cannot see the subtitles when using any dvd player.
  24. The standalone video player also doesn't show subtitles
  25. And the (mentioned) soft players ( VLC / MPC )?
  26. You keep mentioning muxing.
    Are you certain you are simply specifying seperate video, audio, and SRT files to DVDAuthorGui? The prog muxes them, you do not need to perform that step.
  27. Sorry! By muxing I meant using DVDAuthorGUI to put the sound, video and subs together. I just checked a disk I burned and found it works! It has subtitles on both VLC and PowerDVD! Now...I just have to remember which settings I used to make it work! Any suggestions on how to remember?
