  1. Im running an avi through TmpEnc and looking at the size its growing really
    How much bigger dows the mpg-file get when run through TmpEnc?
    Is the filesize that is the result the filesize that is going to be burned or does Nero shrink the filesize when I burn a VCD-CD?
    TIA
    /uffe
  2. depends on 3 things.
    1 what type of mpg you are making
    2 what screen resolution you are using
    3 what bit-rate you are using
    Download a bit-rate calc from the tools section
    use that and you should have a better shot at controlling the size of the output from TmpgEnc.
  3. Tnx!
    Im making a PAL mpeg 1
    But when I lok in the MPEG Settings I can't modify any values
    is this by default in TPEnc or am I doin something wrong
    (The result I got was a 768MB mpeg from a 652MB avi)
    Framerate 25 fps
    Bitrate 1150
    352x288 resolution
    (any of this values I can't change....)
    Hope for more help
    Apr 2001
    florida
    That looks about normal to me.
    Liz
