Just got digital cable today and I am getting some sort of interference in the form of a black bar scrolling accross the picture from right to left when I try to use my 5005. It isn't there when watching tv, only when watching or recording through the recorder. Hook up is composite cables from the cable box to the recorder and composite back to the tv. Any help would be greatly appreciated because right now I can't record anything from tv!
Results 1 to 9 of 9
Does it go away if you disconnect the output to the TV?
Another cause might be unsynced input from other input sources. Best way to troubleshoot is to disconnect things until you discover the source of the problem.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Its most likely Macrovision "protection" that cable companies are using. Technology differs, so I'm not sure the Macrovision hack will fix, but its worth a try if you are willing to change your firmware with an MV hack.
There are posts on this board explaining how. -
Just record, then connect and watch.Originally Posted by hudsonf
This would assume the problem is AC power or video crosstalk.Recommends: Kiva.org - Loans that change lives.
I'm glad Comcast isn't doing that yet. No cable Macrovision here.Originally Posted by Rob61Recommends: Kiva.org - Loans that change lives.
Thanks all. It goes away when the coax is disconnected from the TV. Wish there was a fix for this.
If possible, plug everything into the same circuit breaker to get the grounds matched.Originally Posted by BlazeyRecommends: Kiva.org - Loans that change lives.
Liteon LVW-5005 can’t prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 15:54 -
Recording Video from Cable/TV to DVD-R
By judgmentday in forum EditingReplies: 7Last Post: 12th Feb 2009, 10:03 -
LiteOn LVW-5005 timer recording fails?
By bevills1 in forum DVD & Blu-ray RecordersReplies: 15Last Post: 13th Jun 2008, 10:37 -
Recording Cable TV on my computer
By gabier in forum DVB / IPTVReplies: 4Last Post: 26th Apr 2008, 01:36 -
Recording cable HDTV via firewire
By hipser in forum DVB / IPTVReplies: 3Last Post: 18th Apr 2008, 18:58
