I had a friend I found on teh internet send me an extremely easy and good program for transferring the aac audio to ac3 5.1 so i can keep the 5.1 sound from quicktime movie trailers
before you answer these settings
I have a screenplay 4805 projector and I want these trailers to be able to play on it and on any television that I take the discs to , in other words I dont want the picture to look right on the projector but look squished or oblonged on someones 4:3 tv
when i run the hd 1080 p video through tmpnec express the first selections I can choose are
1.video mode ?
Do I want progressive or interlace
2.aspect ratio
teh default is 1:1 pixel, but there are several choices, which is the best choice ?
3. Frame rate
right now its set to default which is 23.976
4. video bitrate
right now its set on default which is 9198
is this as high as dvd allows or can I up it any ?
5. audio bitrate is set to 192 can it be any higher or is it where it needs to be '
6.video mode ,
its selected to be 3:2 pull down , or there is the options
interlace or progressive which of these do I want
7.what do i need DC compnent precision to be
8.motion precision is set on standard, does it need to be a different selection
thanks please helpt as I CAN FINALLY get these trailers on dvd , but before i DO ANOTHER ONE I want to make sure to have the best settings that I can have
ANSWERS
1.
2.
3.
4.
5.
6.
7.
8.
1. Progressive
2. 16:9
3. 23.976
4. Don't go higher
5. 192 - 224 is fine for 2 channel. 384 or 448 for 5.1
6. for progressive source leave it progressive. For 23.976 apply pulldown.
7. What's the scale ? In CCE terms it would be 9 or 10 for that bitrate
8. The higher you go, the slower it encodes. For your source, standard is probably OK.Read my blog here.
one thing though on number
2 are you sure 16x9 , which 16 by 9 there are two to choose from image 16x9 or ntsc 16x9 remember im wanting this to work on my projector as well as other peoples televions ect -
qoute
my trailers are 1080 p progressive , i guess since it has a p afer it , and you say leave it progressive but change it to pulldown if its 23.976 , thats what it is is 23.976 so which do I go with -
They should be the same unless one is a 1:1 16:9. For DVD authoring, using NTSC 16:9.
If you have set Progressive int he video mode, use pulldown 3:2.
I don't know the software you are using, so I don't know the options it has or how they are laid out. But for 23.976 you must apply pulldown for authoring and NTSC TV playbackRead my blog here.
yeah the progrms im using are tmpgnec express and then using dvd author tmpgnc 1.6
so far ive just used the 1:1 pixel maping , and both trailers look good.
I havent changted it to 16x9 when I do it makes it bigger in the preview picture and makes it look like im loosing a little bit of the sides of my picture
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 04:50 -
Hi-8 tapes need to transfer to DVD
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Apr 2011, 04:42 -
How do I transfer data into dvd.
By millyvanilly in forum Authoring (DVD)Replies: 8Last Post: 24th Jan 2009, 22:34 -
Trying to transfer Digital 8 to DVD
By Johnny Kilo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th Aug 2008, 14:58 -
Adobe After Effects 5.5 Quicktime Compression Setting
By cronk in forum Newbie / General discussionsReplies: 0Last Post: 14th Nov 2007, 20:26
