I have some mpegs that the audio is off sync and is progressively more towards the end of the mpeg. I have finally corrected this problem in capturing which I think was from dropping video frames ever so often but maintaining audio during capture. My question is I have a few files now that I cannot re-capture (Not playing again on sat) and I would like to try and sync the audio back on these. The problem is that a simple audio shift won't do as the audio is progressively off. Is there any program that you maybe mark the start and end of the video then match the audio start and end to correlate? (After de-multiplexing)Someone told me about HTS but I can't seem to figure that out. Any guides, programs, suggestions?
However that is not always the case. You can have a matching audio and video and still have the sync off. In such times, an app like soundforge would come in very handy. It would require you to literally speed certain sections up and slow some sections down throughout the films audio, or adding/subtracting unnoticeable milliseconds here and there. In other words a very timely project, but if the video means that much to you, go for it.
Thanks! Is there anyway (Or program) to insert duplicate frames of video to make up for the sync problem? Funny I don't see any problems with the video but after a lengthy investigation i'm sure the audio sync problem was caused by dropping frames of video ever so often.(Not enough to notice videowize) inserting a dup frame every once in a while should have the same effect (Or better) than shrinking my audio?Originally Posted by mazinz
FWIW...
Demuxing, then comparring length of audio vs video will tell if that's the prob., and probably the easiest thing to check. If the audio length is off by *x* amount at the end of the video, and the start points are identical, then the amount it's off sync will increase from start as it approaches the x, the max difference at the end of the file.
Vegas would probably be the easiest to use for corrections because you literally just ctrl-drag the end of audio clip to match, but at the end of the day you're still just time stretching or compressing.
It is possible for the audio to go out of sync & still be the same length -- audio & video use separate clocks -- but most capture devices guard against this (one of the main design considerations).
As far as altering the video to match, usually don't want to do this unless odd or wrong fps reported -- search forums a bit & online and you'll find plenty of reasons why. RE: dropped frames, often this means dummy or dup frames were added already to maintain sync. At any rate, finding dropped frames is going to be extremely time consuming, if possible.
how to fix audio out of sync in DVD !
By deejay.2001 in forum AudioReplies: 6Last Post: 23rd Jan 2012, 12:19 -
Stretched duration after IVTC (sync issue: audio drift)
By ARTO65 in forum DVD RippingReplies: 11Last Post: 10th Jun 2010, 20:38 -
avi audio out of sync fix?
By the_shyguy in forum Newbie / General discussionsReplies: 7Last Post: 7th Jan 2009, 22:02 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
