I'm using HDTV2DVD 0.4 to convert 24GB of captured .ts from this year's Rose Bowl Game. The input is 1280x720 progressive and DD 5.1 audio. First, HDTV2DVD is a great tool that runs pretty fast ( a plus when you've got 24GB of .ts to convert!) and the audio stays in synch throughout. Just wish I had a option to turn off the DVD VOB creation step - I just need the S2D file, thanks.
BUT.. there's a presistent set of quality issues that I've noticed. First - there's a bit of motion blur - the application appears to retain the progressive encode from the original 720p source - I've found that reencoding with TMPGEnc using Intelace as the encode method produces a smoother result- but the difference is subtle.
MUCH WORSE is the dreaded aliasing/jaggies/stair stepping/barber polling/shimmering anytime the camera pans or zooms against a diagonal line or high contrast stationary image (like the logo on the field).
Any thoughts on how to get around this? I'd be happy to send a small .ts file that illustrates the problem. Whoever solves this gets a commerative 4-DVD copy of probably the best college bowl game this century.
You can send a sample to ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676/HDTVWizard/ and i will take a look.
mpeg2 -> x264 image issues (artifacts in dark areas)
By honelnik in forum Video ConversionReplies: 12Last Post: 29th Apr 2012, 11:13 -
Vegas image issues
By SKU in forum EditingReplies: 0Last Post: 29th Jan 2012, 18:13 -
Eliminating sync issues from bottom of caputured image
By jamesw1008 in forum Capturing and VCRReplies: 4Last Post: 9th Sep 2010, 12:39 -
Folder Icon Image Issues! :(
By lapetite_66 in forum ComputerReplies: 3Last Post: 6th Aug 2010, 23:06 -
Image quality issues, specially in dark scenes..any ffdshow config to help?
By fgtan in forum Media Center PC / MediaCentersReplies: 3Last Post: 13th Nov 2008, 07:26
