Closed Thread
Results 1 to 10 of 10
    Sep 2005
    Canada
    I tried burning a DVD with DVDSHRINK (It works wonders all the time) and it stopped and gave me this info:
    1A20-020E-0000-1349-1210-6697*
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 8:18:06 PM
    Nero API version: 6.3.1.12
    Using interface version: 6.3.1.4
    Installed in: C:\Program Files\Ahead\Nero\
    Application: ahead\Nero - Burning Rom
    Recorder: <HL-DT-ST DVDRAM GSA-4160B>Version: A301 - HA
    1 TA 0 - 6.3.1.12
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    === Scsi-Device-Map ===
    DiskPeripheral : Maxtor 6E040L0 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : HL-DT-ST DVDRAM GSA-4160B atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
    === CDRom-Device-Map ===
    HL-DT-ST DVDRAM GSA-4160 D: CDRom0
    Generic DVD-ROM E: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 36700160 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 223MB (228848kB)
    Free physical memory: 57MB (59352kB)
    Memory in use : 74 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    4.2.2006
    NeroAPI
    12:12:46 PM #1 Phase 112 File APIProgress.cpp, Line 273
    DVD-Video files reallocation started
    12:12:46 PM #2 Phase 114 File APIProgress.cpp, Line 273
    DVD-Video files reallocation completed (no file modified)
    12:12:47 PM #3 Phase 111 File APIProgress.cpp, Line 273
    DVD-Video files sorted
    12:12:59 PM #4 Text 0 File Reader.cpp, Line 118
    Reader running
    12:12:59 PM #5 Text 0 File Writer.cpp, Line 124
    Writer HL-DT-ST DVDRAM GSA-4160B running
    12:12:59 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 817
    DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
    DRM: Beginning burn process.
    12:12:59 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
    First writeable address = 0 (0x00000000)
    12:13:00 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
    12:13:00 PM #9 Text 0 File Burncd.cpp, Line 3167
    Turn on Disc-At-Once, using DVD media
    12:13:00 PM #10 Text 0 File DlgWaitCD.cpp, Line 245
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2286143 (508:01.68, 4465MB)
    12:13:00 PM #11 Text 0 File DlgWaitCD.cpp, Line 257
    Write in overburning mode: NO
    12:13:00 PM #12 Text 0 File DlgWaitCD.cpp, Line 2137
    Recorder: HL-DT-ST DVDRAM GSA-4160B, Media type: DVD-R
    Disc Manufacturer: RITEKG - 05
    Disc Application Code: 64, Disc Physical Code: 193
    12:13:00 PM #13 Text 0 File DlgWaitCD.cpp, Line 418
    >>> Protocol of DlgWaitCD activities: <<<
    12:13:00 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2286144 (2286144) = #2286144/508:1.69
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286144 blocks [HL-DT-ST DVDRAM GSA-4160B]
    12:13:01 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 982
    Prepare recorder [HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682022912, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2286144 | lead-out | 1 | 0x00 | 0x41
    12:13:02 PM #16 Phase 24 File APIProgress.cpp, Line 273
    Caching of files started
    12:13:02 PM #17 Text 0 File Burncd.cpp, Line 4177
    Cache writing successful.
    12:13:02 PM #18 Phase 25 File APIProgress.cpp, Line 273
    Caching of files completed
    12:13:02 PM #19 Phase 36 File APIProgress.cpp, Line 273
    Burn process started at 4x (5,540 KB/s)
    12:13:02 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2345
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    12:13:02 PM #21 Text 0 File DVDR.cpp, Line 1833
    Recording mode: Sequential Recording Mode
    12:13:02 PM #22 Text 0 File Mmc.cpp, Line 20173
    Set BUFE: supported -> ON
    12:13:02 PM #23 Text 0 File DVDR.cpp, Line 1974
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    12:13:02 PM #24 Text 0 File Cdrdrv.cpp, Line 8063
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26127F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Start sector number of the current Border-Out: 2FE10 h
    Start sector number of the next Border-In: 2FFA0 h
    Media Specific [16..63]:
    00 30 01 02 04 06 00 00 - 00 08 00 00 00 00 00 00 .0..............
    00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    12:13:10 PM #25 Text 0 File Cdrdrv.cpp, Line 1293
    12:13:10.109 - HL-DT-ST DVDRAM GSA-4160B\H1 T0 : Queue again later
    12:14:00 PM #26 SCSI -1039 File Cdrdrv.cpp, Line 1441
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x016B0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x09
    Sense Qual: 0x01
    CDB Data: 0x2A 0x00 0x00 0x01 0x3B 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x10
    0x32 0x34 0x00 0x0C 0x09 0x01
    12:14:00 PM #27 CDR -1039 File Writer.cpp, Line 304
    Focus or tracking error
    12:14:00 PM #28 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    12:14:00 PM #29 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    12:14:00 PM #30 Text 0 File DVDR.cpp, Line 2201
    EndDAO: Last written address was 80639
    12:14:01 PM #31 Phase 38 File APIProgress.cpp, Line 273
    Burn process failed at 4x (5,540 KB/s)
    12:14:01 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 828
    DRM: DRM burn session terminated.
    12:14:01 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 857
    DRM: Closing entire DRM handling. Bye.
    Existing drivers:
    File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 9/14/2005 3:17:44 PM (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    my friend also can't get his dvd shrink to work but i don't know if it's the same thing or not.
  2. It could be bad media but I suspect the problem is Nero...try burning with DVDDecrypter or ImgBurn.
    Sep 2005
    Canada
    So does DVDEncrypter Encrypt and Burn? Because I rented a movie and I'm trying to burn it.
    You are in breach of the forum rules and are being issued with a formal warning.
    Copying rented movies is considered warez. We do not discuss that here.
    / Moderator bugster
    Jul 2003
    michigan
    not supposed to copy rented movies
    member since 1843
    Sep 2005
    Canada
    Did I put "rented"? Oh sorry, I meant my own for a relative.
    Jul 2003
    michigan
    not suppposed to make copies for others
    member since 1843
    Sep 2005
    Canada
    what's dvd shrink for then?
  8. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Read the forum rules.
    Jul 2003
    michigan
    to back up your own movies, for personal usage
    member since 1843
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ... and that's a fine Nero serial number, too !
    If in doubt, Google it.
