Ok, I use DVD Fab Decryptor to rip the DVD, DVD Shrink to compress it and DVD Decryptor to burn the final disc. I use Sony DVD-R 4.7GB discs for my backups.
The problem is, there always (except for two occasions) seems to be one skip in the movie, and a few very small periods of glitch or artifacting that occur on each backup. I thought DVD Fab would solve this but it still happens, and with our newer DVD's it gets a bit worse.
The DVDs work fine on the PC, this only happens in standalone players, so is there something I am doing wrong? Would I be able to avoid this by using a different method? It's only a small problem really and they are just backups, but I'm somewhat of a geek when it comes to this stuff.![]()
haha, it's that simple? hilarious! I'll try that. Thanks for the answer bud
I'd suggest trying some other media - issues like these are mostly down to incompatible / bad media.
Some writers/players simply work better with some and not so good with some media.
Is your Sony branded discs really made by Sony? Check the media code (and www.nomorecoasters.com)
/Mats
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 05:35 -
audio glitches
By sandiegoguy in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2009, 15:24 -
Audio Playback glitches
By cmccarty82 in forum Authoring (DVD)Replies: 3Last Post: 13th Jul 2009, 14:07 -
Sync audio with glitches
By kimse in forum AudioReplies: 0Last Post: 22nd Jul 2008, 08:50 -
Trouble makeing a DVD without Glitches
By mongoo13 in forum Authoring (DVD)Replies: 3Last Post: 27th Apr 2008, 04:51
