Hi All
I am trying to remove a hissing noise from a vcd and am hitting obsticles at every turn. Basically I am using TMPGenc to extract the audio from the .dat file and then trying to use Cool Edit 2000 to remove the hiss. The problem is that the file produced by TMPGenc is in .mp2 format which will not be read by Cool Edit (all that happens is the file that is opened is a constant high pitched crackle).
Can anyone offer any advice as to the required software or a suitable tutorial which will enable me to correct the audio and reencode the VCD back together.
Many thanks.
Nokia_veteran
Load the MP2 audio file with Winamp and use the include disc writter plug-in to save it as a PCM WAV file.
Load with CoolEdit and do the necessary noise reduction -- resave as PCM WAV file.
Use your favourite MP2 encoder to reencode the audio (I strongly recommend tooLame -- do not use TMPGEnc's include audio encoder as it quality is not good).
Remultiplex with the video.
Regards.
Michael Tam
w: Morsels of Evidence -
http://www.goldwave.com + Mp3 Plugin
Select Open
Select AVI, Mpeg etc from drop down list
Type *.* for name
Browse VCD and select dat file, and load
Make changes you want
Save as Mp3, or Wav
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 20:16 -
Extract audio only from VCD
By ambrosechapel in forum AudioReplies: 2Last Post: 19th Aug 2008, 21:24 -
extract vidio and audio from VCD
By Z.K. in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2007, 12:50
