Whats the easiest/best/smoothest way to do this?
Why would you want to ?
Easiest way - DVD Remake Pro to join the discs with a simple menu at the top.
Use DVD Shrink or DVD Rebuilder (with custom target sizes set) to squeeze the crap out of them to make the fit onto a single DL disc.
Take pot luck on where the layer break will be.
I don't believe there is a best or smoothest way to do thisRead my blog here.
You need to ask your question with a bit more clarity as to what you intend to accomplish. I made a single DL disk from two DL originals, where the movie was split across two disks, and what I wanted was a single disk with no "disk flipping":
1. Ripped the individual DVDs w/Shrink (no compression) by re-authoring the Movie Only and stripping-out unwanted audio & subtitle tracks.
2. Combined the two titlesets using VOBedit and IFOedit
3. Used PgcEdit to assign the layer break and burn to DL DVD
IIRC after step 2 my combined titleset fit onto a DL disc w/no compression, however it was so big that there was not a good place for the layer break. So I did some slight compression to give me a good layerbreak option.
Combining DVD's
By grandsire02 in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2012, 08:06 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
Combining 2 DVD's help
By rede96 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2009, 15:35 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 21:34
