can anyone help every time i use svcd2dvd i get the this come up (effb2b24-83b4-42a-945b-1f9fab2483fa.exe has encountered a problem and needs to close please tell microsoft about this problem but each time i am getting a different code) i would be grateful for any help as i am new to this
can i see your log?
Starting SVCD2DVD: v1.51.2.0
Begin time: 17:44:55
******** Ripping BIN images to get mpegs (VCDGear )
Analysing File: C:\Documents and Settings\Derek\My Documents\LOST 7\lost 2\lost 7.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
Analysing File: C:\Documents and Settings\Derek\My Documents\LOST 7\lost 2\Lost Season 2_ 6.mpg
++ WARN: mpeg stream contained no scan information (user) data
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
-->Processing 2 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 720
Standard: PAL
Audio SampleRate: 48000
- Leaving lost 7.mpg alone. File has Nav Packs
Type: SVCD
Horizontal Res: 720
Standard: PAL
- Leaving Lost Season 2_ 6.mpg alone. File has Nav Packs
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\BadgerSoft\SVCD2DVD\dummymenuPAL.mpg...
STAT: Processing C:\Documents and Settings\Derek\My Documents\LOST 7\lost 2\Lost Season 2_ 6.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
Creating VTS #2
-->: VTS 02
STAT: Processing C:\Documents and Settings\Derek\My Documents\LOST 7\lost 2\lost 7.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
-->: DVDFolders creating table of contents
scanning C:\Documents and Settings\Derek\My Documents\LOST 7\lost 2\VIDEO_TS/VTS_01_0.IFO
scanning C:\Documents and Settings\Derek\My Documents\LOST 7\lost 2\VIDEO_TS/VTS_02_0.IFO
-->: Creating menu for TOC
STAT: Processing C:\Documents and Settings\Derek\Local Settings\Application Data\Badgersoft\DVD MenuMaker\1.0.2012.28410\7b8dd4a3-c336-4398-9f7c-10b0e2eae942\menu.mpg...
(Total size: 1920MB, Duration: 00:06:35, Rate(MB/Min): 291.28)
System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
at System.String.Substring(Int32 startIndex, Int32 length)
at _2b02761aea07325e.x210ff09a2516b1a7.xf5d131c1b9f0e dc5()
SECOND LOG
Begin time: 08:13:38
******** Ripping BIN images to get mpegs (VCDGear -fix)
-->Processing 0 mpeg files
Creating VTS #1
System.Threading.ThreadAbortException: Thread was being aborted.
at Microsoft.Win32.NativeMethods.WaitForSingleObject( HandleRef handle, Int32 timeout)
at System.Diagnostics.Process.WaitForExit(Int32 milliseconds)
at System.Diagnostics.Process.WaitForExit()
at xb2f2a5866bee3baf.xc5b4b7804027a156.x160a0bf4de8f6 bd0(String xd168ac2ed64c4662, String xa6a477a49a1a2599, String x450f47a9028f884b, xa0efedb9fec1e88f x8b49c96cd0348808, Boolean x74effd3a0f44569e)
at _2b02761aea07325e.x210ff09a2516b1a7.xa727fa5530af9 286()
at _2b02761aea07325e.x210ff09a2516b1a7.xf5d131c1b9f0e dc5() -
No real clues in the log i'm afraid. Can you try with v2 to see if you get the same issue?
thanke Charset: iso-8859-1
will let you know how i get on
derek -
Charset: iso-8859-1 ?
help for svcd2dvd
By dougal69 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2011, 18:05 -
Svcd2dvd
By dobbin in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 24th Jan 2011, 12:19 -
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 12:45 -
Svcd2dvd
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Apr 2010, 05:55 -
svcd2dvd
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th Sep 2007, 12:34
