I copied a movie from TV to DVD. The movie ends in a song, and immediately (less than a second) after the song ended, there was a commercial, which is on my copy. I used DVDshrink to cut out everything after the song ends. (Using reauthor and start/end frames.) I checked the files on my HD by playing them with WinDVD, MPC, and Windows Media Player. There was no TV crap, just the movie. So I burned a new disk and tested it with the same programs. Good movie, and it ends exactly where I wanted it to. But when I play the disk on my desktop DVD player, after the movie ends, I've got this big splash of commercial! What happened? How do I make accurate cuts with DVDshrink?
thanks for any advice.
You cant do it. DVD Shrink isn't an editor. It's ability to reauthor just sections is only I frame accurate. If you want to edit mpeg video, use an mpeg editor such as VideoRedo, Mpeg Tools in tmpgenc, cuttermaran etc.
Read my blog here.
I would have thought "1 frame accurate" was as accurate as you could get. (Shows you how much I know about video!) Isn't video made up of a series of frames? And you just take out the ones you don't want? (Especially since I'm just trying to cut something off the end?)
Not 1 (one) frame, I (eye) frame. Mpeg uses temporal compression, where video is compressed across a series of frames based on the changes between frames. Each series is a called a group of pictures (GOP). The first frame, contains a complete image, the subsequent frames contain only the current frame (actually, this is grossly over-simplified, but it gives you an idea of how it works)
If you cut on an I frame, no encoding is required. As Shrink can't encode, it is restricted to I frames only. Properly built mpeg editors can cut to any frame by re-encoding the incomplete GOP left by the edit.Read my blog here.
then, there are also the bothersome open and closed gops that blur the picture even more.
Learn something new every day, right?
Thanks for the info.
Oh, any idea why it looks good on the computer but not on the desktop player? -
Frame accurate WMV edits
By jbeezer in forum EditingReplies: 5Last Post: 5th Jul 2010, 14:41 -
re-editing edits in videoredo
By krohm in forum EditingReplies: 2Last Post: 22nd Apr 2010, 13:02 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Is There A Program That Edits Without Transcoding?
By blazin-j in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 04:05 -
Freeware program that edits movies
By LITEONDVD in forum EditingReplies: 3Last Post: 21st Jul 2007, 10:25
