Not sure if this is the correct forum for this post but here goes:
I have a three port firewire card plugged into my computer. Into those ports I connect my external firewire hard drive, as well as my video camera.
I am using Vegas 6.0- captured the media to my firewire drive, dropped it onto the timeline in Vegas and am using that video camera as the video preview device (TV connected to it)
The problem seems to be that when I turn on the external preview in vegas, it starts to show that preview on the TV, but then flickers back to just the blue screen of the video camera, and it keeps changing every 2 seconds rougly. The audio however, plays fine (I guess because there is no audio signal sent through the firewire)
To me it seems like having both the hard drive with the media on it as well as the camera connected to the same firewire card is causing this.. Is there any way to avoid this?
Thanks,
Mike
Results 1 to 14 of 14
Originally Posted by sdsumike619
1. Does the monitor "interference" correspond to hard disk activity on the firewire drive? Does the interference go away if you preview a file from the internal drive?
2. You can set Vegas to send audio to the firewire preview or to your sound card. Forget which menu.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
yep, it sure does, that's what I observed..If I put the stuff on my internal drive, it doesn't flicker...the audio i'm not worries about, it's the video preview problem
A second IEEE-1394 card may help.Recommends: Kiva.org - Loans that change lives.
I wrote to western digital, so we'll see what they come back with regarding this....
Just to be clear, an IEEE-1394 or USB2 hard disk controller is a software driver unlike a hardware EIDE (PATA) or SATA hard disk controller.
are you saying that I need to install a software driver for my firewire card? I didn't, I assumed that the windows xp plug and pray would work find and it appears to be except for this problem
PS: actually that is history. Today there is default HDD driver software in XP/DirectX and it should be plug and play. This makes it difficult to know which tech support to call, but I'd start with the HDD manufacturer. The external drive unit contains an EIDE hardware controller in the drive and bridge hardware to IEEE-1394.Recommends: Kiva.org - Loans that change lives.
the external drive unit contains an EIDE hardware controller in the drive and bridge hardware to IEEE-1394.
If the external drive was made by Western Digital, I'd call their tech support first for advice.
http://www.microsoft.com/whdc/system/bus/1394/1394tech.mspxRecommends: Kiva.org - Loans that change lives.
i read the microsoft link but it didn't have any info regarding my problem ?
I could only find this one for Win 2000. Maybe they never fixed it.
http://support.microsoft.com/default.aspx?scid=kb;en-us;281695Recommends: Kiva.org - Loans that change lives.
"maybe they never fixed it"
this should be microsoft's new trademark!!!
but yes this article you pointed me to is pretty much what is going on with my issue.. =( How did you find it? -
Google
Just call Western Digital Support. They should know what is going on and it it their product.Recommends: Kiva.org - Loans that change lives.
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 16:45 -
Interference from Firewire??
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Nov 2008, 14:52 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 14:35 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 09:20
