Hello Everyone,
I've been a long time reader, but this is my first post. I've got a problem.. when I burn an episode (season) DVD - using Clone DVD / Any DVD & a pioneer 110D, then go to play it, the disc starts playing episode 3 or 4 (etc) - i.e. it doesn't start with the menu as the orginal does.
Do you know what I'm doing wrong? It's really bugging me.
BTW - I got the same problem with Shrink 3.2, but not with DVD2One, which I trialed (but didn't buy as I've got Clone).
Thanks for your help, I really do appreciate it.
Results 1 to 11 of 11
I have all the same programs you have but for episoded dvds "1 Click DVD Copy" is the best product I have used along with any dvd . Lou
thanks Lou, but does anyone know a way of using Clone? I appreciate your help, but I don't really want to buy another prog.
yes, that's why I'm co confused. The menu's are there - but I need to press "menu" to actually get them up. So, when I put the disc in, it starts with one of the random episodes. Then I press menu and select 'episode 1'
strange... -
Try burning with a different program,Nero for example. I used ClonedDVD to B-U Farscape. I deleted all the extras and preserved only the episodes and menus. Never had aproblem. Also look at the file structure in explorer. Are all the files there that were on the original?
thanks Wolf... do you mean create a VOB with Clone and then use Nero? If so, I'll give it a go
Removing PUO's when ripping can cause this also. The odd standalone player (ex LG's) have remove PUO's as an option, disabling this will correct it IF that's what's happening.
how many episodes can you get on a single layered disc,before losing to much quality?
thanks -
I'm having the same problem with Disc 5 of Veronica Mars Season 1.
I was able to back up disc 1-4 & 6 using DVDFab Decrpyter and then using Clone Dvd2 to separate 2 episodes per disc. Then I use Nero or Roxio Media Creator 7 to burn the discs.
I've burned disc 5 four times and they still are not working. I'm using Memorex Dvd-rs and the other dvds are working in my dvd player.
I backed up disc 6, which only had 2 episodes, and that disc has no problems.
All software are the latest versions and I haven't had a problem with other titles.
Thanks for your help.
DVD Episode Problem
By jackowens in forum MediaReplies: 23Last Post: 12th May 2011, 10:59 -
DVD Copying Problem
By Live2WinForever in forum DVD RippingReplies: 4Last Post: 24th Feb 2010, 03:02 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 11:42 -
Problem copying pictures off DVD...
By impmon2 in forum DVD & Blu-ray WritersReplies: 7Last Post: 21st Apr 2009, 23:45 -
Problem Copying Homemade DVD
By Anonymous642 in forum Newbie / General discussionsReplies: 8Last Post: 28th May 2007, 13:04
