Ok here's the deal: I encoded a movie in VCD format (for some weird reason) using TMPGEnc. For my first rip, the result was good, but I'm thinking if I should re-encode the whole film in SVCD format. What are the benefits? Would you do it, or wouldn't you really bother?
Thanks.
Start with dvd again, if you want SVCD. VCD to SVCD is useless, because you lost the quality alreaddy.
Yep, that is what I was planning to do - start with the DVD again, but I'm asking if there's any point. Will I notice a huge difference between VCD and SVCD?
SVCD looks better than VCD, because a higher picture resolution is used, 480x480/576 instead of 352x240/288. So the picture is more detailed, clearer, sharper or how ever you want to call it. Higher resolution usually requires a higher video bitrate as well, so the file size get larger.
keep in mind SVCD has better compression than VCD...so SVCD gives you "more bang for your buck"..in terms of file size
how to encode?
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2012, 12:12 -
A free way to re-encode?
By Paladinleeds in forum Video ConversionReplies: 6Last Post: 3rd Sep 2011, 10:13 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Why do I have to Encode?
By gilamran2 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2008, 04:29 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 11:03
