Results 1 to 9 of 9
  1. My Sony software dumps mpeg file on my hard drive, how do I use Nero to burn them onto a DVD?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If you don't have Nerovision in your release, you need to upgrade.
    www.nero.com
    http://www.kiva.org/about
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    then rtfm
    In answer to the question posed in the post subject;
    You can use a hammer to fix a bicycle, but why would you. Just because something can do a job, doesn't mean it is the best tool for the job.
    Read my blog here.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If it's a DVD compliant mpg, just author it with a decent authoring app like TMPGEnc DVD Author (or GUI for DVD Author, or DVDAuthorGUI or...)
    ...and what guns1inger said.
    /Mats
  5. Member bendixG15's Avatar
    Aug 2004
    The el cheapo Nero 6 that you buy on eBay do not have the DVD burning programs. You got to buy that as an add-on.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...just to find it's crap in comparision to many (most) completely free tools.
    Nero can well be used for writing data to CD/DVD. Not much else.
    /Mats
  7. yep, they attempted to throw in too much stuff into nero......trying for an all in one app, however they botched it up too much for my liking........we need something to burn discs, not compress video, compress audio, capture, clean your kitchen and do your laundry....for capturing give virtualdub a run, for conversion to mpeg, give quenc a run...authoring, give dvd lab pro a run, and consider purchasing, and nero...well you probably already have that since it was brought up in the discussion to begin with
  8. Thanks guys, I downloaded Nero Vison, But when I burnt my mpegs to the DVD it brought up a message about Dolby Sound, In my haste to get the job done I ignord it now I dont get any sound, and the message wont come back up with the required links. How do I get sound?
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Sp despite what we suggested, you went and got NeroVision anyway. Shame on you. And surprise surprise, it didn't work.
    I believe you have to go and pay for a Dolby Digital plugin from Ahead to get AC3 working in NV. Just more $$$$s down the toilet.
    Read my blog here.
