I own a copy of Family man on dvd and want to back it up, due to some small scratches on it. I tried to use my 1clickdvd and even dvdfab. both do not find it. For 1click it says it can not open video_ts.ifo. Verify your source in the options dialog. I do and still same error.
Arghhhh
Help please
Try using DVD Fab Decrypter and after ripping the DVD, browse for the folder VIDEO_TS
If the scatches are bad enough that this software won't read it chances of producing a good backup without errors is next to nil. This movie is under $10 at Amazon or at Walmart for $5.88. If a good backup is important you may want to consider those options.
ok I did get dvd fab decrypter to get it to the hdd. But I tried to bring it back now to a dvd with 1clickdvd and it starts fine then dies after 5mins saying the program encountered an error and needs to shut down. I have rebooted but same error. Any ideas?
Thanks -
Too many disc errors on the original to get a clean backup. It's cheap movie to buy a backup. All the discs and you've spent might be better spent on visiting your local media outlet.
HD data recovery of family videos
By Arrriba in forum ComputerReplies: 3Last Post: 9th Jul 2009, 23:27 -
I can't believe that there hasn't been a Family Guy episode about this!
By zzyzzx in forum Off topicReplies: 7Last Post: 11th Feb 2009, 02:51 -
Convert Iron Man BD to MP4 using RipBot - Audio Channel Issue
By csilvest in forum Blu-ray RippingReplies: 5Last Post: 27th Jan 2009, 10:25 -
family movie night
By Aski in forum Off topicReplies: 2Last Post: 11th Jan 2008, 14:27 -
Family tech support
By rallynavvie in forum ComputerReplies: 40Last Post: 18th May 2007, 11:41
