I have a PAL avi which is 640x352, so almost 16:9 and far from 4:3.
Having read the doom9 guide:
http://www.doom9.org/index.html?/mpg/cce270.htm
I tried it out and seems to produce fine results but got me thinking that I could do it the other way because doing it that way made a 4:3 DVD whereas my source is more 16:9.
PAL dvd is 720x576, 16:9 DAR flag would stretch this to 1024x576.
To scale up the width to 1024 I multiply by 1.6 so to scale up the height I multiply 352*1.6 to get 563.2. Round up to 564. So I need some black boarders. 576-564 = 12 Thus only bars of 6 pixels need to be added to the top and bottom.
So I write an avs script:
AviSource("F:\test.avi")
Lanczos4Resize(720,564)
AddBorders(0,6,0,6)
Then encode with a 16:9 DAR.
I can then use this to produce a proper 16:9 DVD. If I do it the doom9 way I have to make a 4:3 dvd to get a proper picture.
As a newbie to this, I may be missing some things so if someone would read over this and give some comments, I would be very greatfull.
You have missed some fundamentals along the way. The biggest thing you have missed is the fact that TV pixels are not square. On the PC, AVI files generally have a Pixel Aspect Ratio of 1:1 - i.e. square. Television pixels are not square, and each format and AR combination has a different pixel aspect ratio.
Have a look at either FitCD or Paranoia to see how these programs calculate their numbers. It's not quite as simple as you think.Read my blog here.
If the resize looks fine to you then that's all that matters really. Whenever I do stuff like that I open the avisynth script up in virtualdub and check it out. Also, you could try enooding just a small sample of the clip and test it out on your tv.
Have a read of this -> http://www.mir.com/DMG/aspect.html
Especially the Handy Reference Table. This was my key reference when I wrote my own resize app (see my sig)
The tip about using virtualdub to check your sript is a good one as well. You can right-click on the preview screen and change the aspect ratio to 4:3 or 16:9 to see how it will look with the correct pixel aspect ratios applied. Try to find some scenes with wheels or other round objects - you will soon know if you have distorted things.Read my blog here.
Resize aspect ratio.
By Benhermies in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2011, 23:29 -
Avisynth Aspect Ratio Resize Help
By t4com4 in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2010, 11:30 -
Resize 1920 and 1440 same aspect ratio?
By khan.cross in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 13th Aug 2010, 12:34 -
how to change aspect ratio of video?
By curt1sw in forum EditingReplies: 2Last Post: 25th Nov 2007, 08:42 -
how to change the aspect ratio of a video?
By curt1sw in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2007, 09:46
