Can Someone recomend another dvd player that I can buy that will play dvd-rw. So I can record with the pioneer on the dvd-rw and playthe recorded movie in another room. I am looking for a dvd player under 100 dollars
thank you
Are you currently having trouble playing the DVD-RW discs you created onOriginally Posted by duffer75638
your Pioneer 533-h ?
You *may* accidently have set the default to create the disc as DVD-VR,
which is much less compatible than a disc created with DVD-video as the
selected setting.
You can check your setting by putting the DVD-RW disc in the tray and
pressing these remote buttons:
Home Menu -> Disc SetUp -> initialize -> and then select the DVD-video
setting to initialize the disc (warning !!! This will erase the disc).
Pioneer 533 DVD-R Burning Problem/Question
By tcfrerich in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2009, 13:03 -
Anyone using a P4 3.06GHz / 1M / 533 SL7DT 478pin CPU
By blinky88 in forum ComputerReplies: 13Last Post: 2nd Sep 2008, 12:47 -
No picture with Firewire connection to Pioneer 533 h
By Knightmessenger in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Aug 2008, 16:10 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59 -
1GB DDR2 667/533 DIMM $39.99 at Micro Center Worth it?
By louv68 in forum ComputerReplies: 5Last Post: 10th May 2007, 12:54
