Anyone had any experience with these?
I love the datawrite grey single layers.
Results 1 to 12 of 12
Undoubtedly a Ritek DL disc.
he said undoubtedly, not unfortunately...but yes, in the case of dual layer discs, it is unfortunate...........stick to verbatim's with the dual layers.
CMC MAG D01 is the dye on them,and really,they should be called datashite titanium 2.4speed DL discs.
utter crap,i tried a pack,albeit at a reduced price of £10 for 10,and never again.
not had a problem apart from a couple of ritek ones,no problems with verbatim,but these,man,what a crock of shite they were the burns were bad,playback was extremely flawed,lots of breakup,and my players didnt like the layer changes,just too much of a pause,and then 9 times out of 10 it would spit it out.
and that was using decrypter iso read/write.
i actually thought they were fake,as the quality in the tub was mediocre at best,lots of scratched edges,and some spots that looked almost like grit on the disc surface,and that was a sealed tub.---advice-STAY AWAY,spend your cash on some quality verbatim.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
The ones I used (I have 6 of them) had a printable surface and were 2.4x. I burned mostly archived data to them and haven't had any problems reading from them. One or two of them have movies (DivX) on them and they play fine in my external players and recorders. No issues to report. I was given them from a friend who said he didn't like them for the same reasons RottenFoxBreath posted.
You may want to heed the advice provided. Verbatims seem to be quite reliable amongst everyone I've talked to. They are also one of the more cheaper name brand discs. -
yeah,price was a thing for me for a while,but verbatims were the same price as the full price tub of datawrite titaniums/ritek(or another random named disc),which i found strange,but never one to look a gift horse in the mouth.Originally Posted by ROF
Unfortunately a RITEK DL.
My mistake on my post, lordsmurf. Knowing your feelings on Ritek disks, I read it as "unfortunately".
TANSTAAFL
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
HELP!! Dual Layer Problem with Titanium 10
By mnelson220 in forum MacReplies: 20Last Post: 21st Jan 2009, 00:50 -
Double Layer DVD
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2007, 20:09
