Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I have a few .avi divX films that are just slightly too long to fit on a CD-R, even with overburning software (Firestarter).
    I was wondering if ffmpegX is able to cut a tiny bit off the end or beginning of such files..? Or should I use QT Pro with a divX plugin? But I thought I heard on this forum that divX QT plugins dont work in Tiger yet...
    Any advice please?
    bllx
    Actually VLC reports the video codec as "DX50" ...is that a divX flavour...?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by bllx
    I have a few .avi divX films that are just slightly too long to fit on a CD-R.
    Some put several avi movies on a DVD, which makes 718 MB files trivial.
    I'd give Explicit or Mpeg Streamclip a try.
    Yeah, that fourcc identifier was introduced with DivX 5.0.
  3. Use VirtualDubMod with both audio and video in Direct Stream Copy mode. Use the mark-in and mark-out markers to mark what you want to keep. Save AVI.
  4. Thanks a lot for the suggestions.
    Explicit seems very clear and simple, nice easy way of splittiing .avis.
    Thanks again,
    bllx
