hello
I have been using DVD lab Pro and when creating Menus
I type in text and when I compile the DVD- the text is invisible until you mouse over it.
I use a Movie as my background which is mostly black
I'm going nuts trying to figure it out- I have been thru the PDF help file but it does not work--Also when you mouse over it it is an ugly pink I don't know what to do
You might want check this section -
http://www.mediachance.com/dvdlab/Help/links.htm
Specificaly the Visibility section. -
it's the bloody same as the PDF help file
it's not good and the visibility talks in Jargon
it says Visible- It's always visible on a background---WELL I havn't doen anything and it isn't visible
I even move the drop down menu to Visible and it is still invisible -
Did you "render" the menu into a video after you added the text
hmmmm---no I didn't read that part in the help file
I'll check it out
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 07:03 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
DVD Lab Pro Transitions question
By phatk9999 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2008, 04:06 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 23:26
