Hi I tried to convert a avi and a mpeg file to 3gp but ffmpeg creates a file
.3gp with 0 kb.What can I do? Thanks.
If this is for the Mac, I can't help. If this is in regard to a PC (as your computer details indicate), I think you may be in the wrong forum. Anyway, if it is for the PC, you should try SUPER. It is a free "frontend" for several encoders and everything you need is installed automatically. It has presets for 3gp output. I use it frequently and it works wonderfully. The main site is www.erightsoft.com.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited."
Thanks for the help but you're right I'm in a mac so super doesn't work. For the moment I'm converting with QT but I suppose ffmpeg is faster adn gets better quality than QT,isn't it?
Convert AVI to 3GP with Minimum frames-per-second
By JamesC2000 in forum Video ConversionReplies: 1Last Post: 7th Nov 2011, 14:23 -
3gp Videos in MPEG Streamclip
By betomon in forum MacReplies: 3Last Post: 5th Dec 2010, 07:20 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 15:58 -
Converting 3gp to MPEG4 .AVI
By vworley in forum ffmpegX general discussionReplies: 9Last Post: 2nd Apr 2008, 12:48 -
Converting MPEG to 3GP --> Empty Target File?
By SnakeGirl in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2008, 00:14
