I could use some help, I am made a change disc flash file for the end of my vcd disks, simply telling you to chnge to the next disk. Exported it to .avi in 352x240, 24bit, no sound. Then converted to MPEG with TMPGEnc and added it to a VCD burn compilation. The flash file gives errors in Nero 5.551 and will not burn to VCD.
Any suggestions??
BTW, I searched the forums already, there is no posts that relate to this that I could find.
Nero has a problem with the mpeg file you're giving it. I'm betting it is looking for an audio track.
Just a thought, but I've always added a blank audio track. Just use windows recorder and record (x) seconds of silence to match the video length then mux it with the avi into an mpeg file. -
I will give that a try. I made an intro with no audio track and Nero burns that just fine, it was not with flash, but with premeire.
*sigh* I will have to wait another hour and a half, Im encoding a flick right now.
I will let you know how it turns out, and thanks for the reply.
File sorting from flash drive problem - Phillips DVP5990
By Halcon in forum DVD & Blu-ray PlayersReplies: 4Last Post: 9th Apr 2012, 17:13 -
File thumbs changing after conversion...Is this a problem?
By llllllllll in forum Newbie / General discussionsReplies: 8Last Post: 10th Mar 2011, 12:21 -
MKV VIDEO CONVERSION, problem with the quality of the output file.
By pay1000 in forum Video ConversionReplies: 11Last Post: 25th Jun 2008, 02:46 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
Joined avi file conversion problem
By siberian50 in forum MacReplies: 12Last Post: 26th May 2007, 19:04
