I have been using Nerovision Express 2 to author and burn.
I downloaded the new Womble Mpeg Video Wizard-DVD tonight to try it out. I have bought the Mpeg Video Wizard and like it, so I figured I'd try their authoring app. One thing I noticed is that I seemed to be able to add more files using the Mpeg Video Wizard, which seemed odd.
Using Mpeg Video Wizard I was able to add the same 12 minute 37 second video clip 9 times before nearing the capacity of the disc. Then I opened up Nero and I could only get 7 of this same clip. It told me I was over the disc capacity when I added the 8th file.
I fact, I have noticed that using the Nero product I can only get about 3.6 gigs on a disc using their authoring app. Any input appreciated- thanks!
It's hard to tell what Nero is doing, maybe reencoding. That's one of the reasons many of us don't use it for encoding or authoring. It does well at burning though.
I haven't tried Womble for authoring. I use TMPGEnc DVD Author most of the time because it's easy. It has a trial version also.
And this is mainly an authoring question. Moving you. -
Nero may be converting your audio to PCM which takes more space.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
After checking into it, this is exactly what is happening. I don't think there is anyway to stop this- at least I couldn't find it. When I first tried to burn a clip with AC3 audio, it told me I had to pay for the Nero AC3 plug-in, which I bought and downloaded ($20 I think). I assumed then I was keeping the AC3 audio- wrong.
Time to find a new authoring app. -
Originally Posted by Lem Motlow
Nero may be fine for writing data to disc, but that's about it.
/Mats -
http://img132.imageshack.us/img132/9711/clipboard022cy.gif
change Automatic to DolbyTam -
That's for encoding the audio to 2 chnl AC3 - not keeping the already good and dandy AC3 from the source file.
/Mats
Missing Audio after DVD authoring using Nero Vision 10
By Deerkiller in forum Authoring (DVD)Replies: 0Last Post: 11th Sep 2011, 21:18 -
Blu-ray authoring with Nero?
By tomkat in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2008, 17:48 -
A question on re-authoring
By teabagg in forum Authoring (DVD)Replies: 1Last Post: 22nd Nov 2007, 21:14 -
Coming soon Nero 8 with HD-DVD and Blu-ray authoring
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 15th Sep 2007, 12:22 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 02:40
