(Sorry, I don't know where to post this. I did a search for Video and audio out of sync, but it didn't give me a option to post in that section unless I wanted to post in someones thread. I found a lot of information but I'm unsure of where to start.)
I have some Video avi files that I want to make a DVD out of in Pinnacle Studio 8. When I play these files in Studio 8 the audio and video are out of sync. When I play them in Windows media player there is no problem, they are normal in sync. I used a software called GSpot and this is the information it gave me:
VIDEO
4CC: YUY2
NAME: YUV PACKED 4:2:2
STAT: NO CODEC NEEDED
RUNTIME:00:05:33 (9,985 fr)
XY:352x240 (1.47:1) [=22:15]
BITRATE:24268 kb/s
FPS:29.971
QF:9.585 bits/pixel
AUDIO
STAT:PCM:NO CODEC REQUIRED
BITRATE:1411 kb/s (705/ch, stereo)
FS:44100 Hz
STREAM TYPE A/V INTERLEAVE
TYPE: OpenDML AVI
IMRR:N.S
I/L: NOT SUPPORTED
Does name indicate the codec?
What is my first step into resolving this problem?
Two main kinds of sync problems. In one the audio is out of sync the same amount for the length of the video. This means the start point of one or the other needs to be offset.
In the second kind the audio gradually drifts out of sync and is worse at the end. That usually means the video or audio is different lengths.
So you add or subtract a offset or you change the length of one or the other. Unfortunately, you need to know exactly how much of a change is needed. And just to make it complicated, the video may have errors and have some combination of both problems.
You change the length of one of the files in a audio or video editor.
You can add the offset in either, too.
I would drop it into VirtualDub Mod and check the length of the video/audio and check for errors in the file. You can change the offset in VDMod and the audio length in Audacity, both freeware.
There is also this guide:
https://www.videohelp.com/forum/userguides/140540.php
That should get you started, and you can do a forum search for 'sync problems' and get a few hundred posts on the subject.
OK, I used VitualDubmob to scan for errors and here is the result:
0 frames masked (0 frames bad, frames good but undecodable)
And here is the stream report:
----------Video Stream---------------
-Source: [input AVI file]
-Description:AVI video stream
-Length: 00:02:18:547
----------Other Stream--------------
-Description: AVI Audio Stream 1 [tag 0x0001, Microsoft PCM format]
-Length: 00:02:19:078
So there is a difference of 0.531 between the video and audio streams. This video is out of sync right away. It dosen't gradually become out of sync. So well the link you gave me still help?
Also how do you change the offset in vdmod? And what does it mean to change the offset? -
Ok, I followed your instructions. The only thing I changed was the audio skew correction because the audio was lagging the video. Was I supposed to play with the interleaving options? I found no reason to do that in the help files. I set the video and audio direct stream copy and saved it.
Now I'm using Studio 8 to make the DVD. The video and audio is generaly good however, in some parts of the video it seems like the video pauses for a brief moment so that the audio can catch up. But this is in Pinnacle Studio 8. Is this a side effect of the method you have shown me or do you think it may be Pinnacle or my computer? I have 1 GB of RAM. The video is fine when viewing in VirtualDubMod.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 22:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 13:30
