This just started happening. When shrinks completes it's analysis and encoding and the disc is just about to pop out I get "Error:\nCannot connect TRF". I have no idea what is causing it. It looks to be related to Nero in some way. Below is the entire error message and it is quite lengthy. The compression actually does complete. I just can't put in a blank disc and continue the burn. Looked on the internet and saw that this error was related to Nero. Any suggestion would be appreciated.
Joe
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 5/6/2002 10:01:14 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero API version: 6.6.0.16
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 16b
Recorder: <PIONEER DVD-RW DVR-109> Version: 1.58 - HA 1 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral : TOSHIBA DVD-ROM SD-M1712 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-109 atapi Port 1 ID 0 DMA: On
DiskPeripheral : WDC WD1200JB-32EVA0 15.0 viaraid Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
TOSHIBA DVD-ROM SD-M1712 G: CDRom0
PIONEER DVD-RW DVR-109 D: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047276kB)
Free physical memory: 444MB (454828kB)
Memory in use : 56 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
31.1.2006
NeroAPI
7:44:12 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
7:44:12 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
7:44:12 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
7:44:13 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
7:44:13 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
7:44:13 PM #6 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-109 running
7:44:13 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
7:44:13 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3309
7:44:13 PM #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
7:44:13 PM #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286111 (508:01.36, 4465MB)
7:44:13 PM #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
7:44:13 PM #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: PIONEER DVD-RW DVR-109, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AE1
Disc Application Code: 64, Disc Physical Code: 193
7:44:13 PM #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
7:44:13 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [PIONEER DVD-RW DVR-109]
7:44:13 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [PIONEER DVD-RW DVR-109] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286112 | lead-out | 1 | 0x41 | 0x00
7:44:14 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
7:44:14 PM #17 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
7:44:14 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
7:44:14 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 8x (11,080 KB/s)
7:44:14 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:44:14 PM #21 Text 0 File DVDR.cpp, Line 2379
Recording mode: Sequential Recording Mode
7:44:14 PM #22 Text 0 File Mmc.cpp, Line 21708
Set BUFE: Buffer underrun protection -> ON
7:44:14 PM #23 Text 0 File DVDR.cpp, Line 2534
Start write address at LBA 0
DVD high compatibility mode: Yes
7:44:14 PM #24 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 30 00 10 20 00 00 00 - 00 00 00 00 00 00 00 00 .0..............
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:44:16 PM #25 Text 0 File Cdrdrv.cpp, Line 1286
19:44:16.296 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:41 PM #26 Text 0 File Cdrdrv.cpp, Line 1286
19:44:41.921 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:41 PM #27 Text 0 File Cdrdrv.cpp, Line 1286
19:44:41.968 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #28 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.000 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #29 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.046 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #30 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.078 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #31 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.125 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #32 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.156 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #33 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.203 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #34 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.250 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #35 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.531 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #36 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.734 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #37 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.765 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #38 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.812 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #39 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.843 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #40 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.890 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #41 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.921 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:42 PM #42 Text 0 File Cdrdrv.cpp, Line 1286
19:44:42.953 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #43 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.000 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #44 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.281 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #45 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.468 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #46 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.515 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #47 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.546 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #48 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.578 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #49 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.625 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #50 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.656 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #51 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.703 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #52 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.734 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #53 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.812 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #54 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.859 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #55 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.890 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #56 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.937 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:43 PM #57 Text 0 File Cdrdrv.cpp, Line 1286
19:44:43.968 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #58 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.000 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #59 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.046 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #60 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.140 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #61 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.171 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #62 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.203 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #63 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.250 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #64 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.281 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #65 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.328 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #66 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.359 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #67 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.437 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #68 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.468 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #69 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.515 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #70 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.546 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #71 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.593 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #72 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.625 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #73 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.656 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #74 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.765 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #75 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.796 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #76 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.828 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #77 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.875 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #78 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.906 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #79 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.953 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:44 PM #80 Text 0 File Cdrdrv.cpp, Line 1286
19:44:44.984 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #81 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.031 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #82 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.062 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #83 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.109 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #84 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.140 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #85 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.187 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #86 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.218 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #87 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.250 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #88 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.296 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #89 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.390 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #90 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.421 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #91 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.468 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #92 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.500 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #93 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.531 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #94 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.578 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #95 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.609 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #96 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.703 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #97 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.734 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #98 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.781 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #99 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.812 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #100 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.859 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #101 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.890 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:45 PM #102 Text 0 File Cdrdrv.cpp, Line 1286
19:44:45.937 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #103 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.031 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #104 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.062 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #105 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.109 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #106 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.140 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #107 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.187 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #108 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.218 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #109 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.250 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #110 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.343 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #111 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.390 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #112 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.421 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #113 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.468 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #114 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.500 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #115 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.531 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #116 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.578 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #117 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.656 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #118 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.703 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #119 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.734 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #120 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.765 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #121 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.812 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #122 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.843 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #123 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.890 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:44:46 PM #124 Text 0 File Cdrdrv.cpp, Line 1286
19:44:46.984 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
7:45:46 PM #125 SCSI -1135 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x00F50000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0x4C 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x03 0x4A 0x00 0x0E
0x00 0x00 0x00 0x00 0x0C 0x00
7:45:46 PM #126 CDR -1135 File Writer.cpp, Line 311
Write error
7:45:46 PM #127 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:45:46 PM #128 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:45:46 PM #129 Text 0 File DVDR.cpp, Line 2774
EndDAO: Last written address was 216255
7:45:46 PM #130 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 8x (11,080 KB/s)
7:45:46 PM #131 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
7:45:46 PM #132 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 5/6/2002 10:01:08 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.53a, size=17136 bytes, created 6/20/2003 7:36:36 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=4, 3, 20, 1, size=101504 bytes, created 7/25/2005 11:53:28 AM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 20, 1, size=29696 bytes, created 7/25/2005 11:53:04 AM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 20, 1, size=8704 bytes, created 7/25/2005 11:53:30 AM (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 12 of 12
Guessing, does Nero write to DVDs properly?
Ask because you've got aspi & prassi installed from the tail end of your log. Incd can also be just generally problematic.
At any rate, can always create layout with shrink & burn separately, or to diagnose try to temporarily disable prassi, &/or incd? Try to reinstall Nero, &/or try their tools to clean system? -
I can burn the DVD on Nero after the error message pops up on Shrink. But it takes much longer to shirnk the Movie with DVD shrink and then burn it on Nero. Up to now I realized what a great burniing tool dvd shrink is for a piece of freeware it still competes with anything out there today. I have changed nothing on my system, DMA is enabled. I think I may try their clean system tool you speak of , I did not know there was such a tool available on their web site.....thanksOriginally Posted by mikiem
Well no luck on the cleaning tools, I unistalled INCD with no luck. Tried to remove and reinstall Nero, ran all of their cleaning tools. I'm kind of stuck doing the shrink with DVD Shrink and burnning with Nero until I can get some better information. Any other suggestions from anyone??
Just a thought. Do you have the absolute latest nero updates installed?
My dvd shrink was working fine untill i put in a new hard drive( last week).
I reinstalled nero 6.6.0.12 then upgraded with their latest version which i think is a new January upgrade. Since then i have the same problem too. -
Let DVDShrink rip to ISO. Then burn ISO with DVDDecrypter/ImgBurn.
/Mats -
I'm wondering if the dude who created DVD shrink whom is now working for Nero put this problem in the new version so we'd use Nero to burn. It actually started just before I upgraded with their latest Jan upgrade. It's a hassel because shrink burns a movie in about 1/3 the time Nero does. I'm thinking about rebuilding my system anyway because of spyware I can't seem to get rid of. Perhaps that will fix it.Originally Posted by edwaggs
Nothing to gain by doing this, I let DVD Shrink compress the original then I just burn with Nero.Originally Posted by mats.hogberg
I just downloaded Nero's latest update (a little behind in my updates) and now have the same burn error message using DVD shrink. I have always used Nero for my burns but now I am unable to burn using the standard Nero Burning Rom program. Just for giggles I took the decrypted files and used Nero Recode to analyze (again), encode (again) and burn. No problem. So why can't I burn using Nero Burning Rom program?
Thanks -
Not that much different from my modus operandi:Originally Posted by JoeCegan
I let DVD Shrink compress the original then I just burn with DVDDecrypter. Only difference is that my way uses only freeware apps, and DVDDecrypter has been proven the most reliable DVD writing app there is. Possibly now rivalled by ImgBurn.
/Mats
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28 -
VirtualDub & VirtualDubMod Error Messages..R & R
By sandman423 in forum EditingReplies: 4Last Post: 18th Oct 2007, 06:30
