I have downloaded an avi file from my
camcorder and it have 13 GB. How can
I put it on a dvd? what app can I use?
Can use DIKO?
Thanks a lot and sorry for my english.
Fiona from Argentina
DV format or AVI captured?
I've had good luck with DivxToDVD for quick and easy DV to DVD. There is a freeware version available. If you have Hi8 or similar, it will also work.
If it's DV format a better way with more control and quality is to transfer it to your computer with WinDV, edit with VirtualDub Mod, encode with a regular encoder like TMPGEnc, then author with a program like TMPGEnc DVD Author and burn to DVD.
If you look to the left under 'CONVERT' you should see some good 'How to' guides for that type of conversion. <<<<<<
EDIT: And DIKO should work also, but I prefer DivxToDVD.
i have a question. DVD to a single avi/mpg.
By adan_4u in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 23:22 -
AVI to DVD Question
By Cyberian75 in forum Video ConversionReplies: 2Last Post: 8th Jul 2010, 19:06 -
AVI to DVD audio/video question
By Iconoclast_211 in forum Newbie / General discussionsReplies: 3Last Post: 25th Mar 2009, 12:00 -
AVI ---> DVD question
By arcticmoonshadow in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 21:40 -
AVI to DVD question
By cajmere in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:29
