can anyone recommend a deep scratch remover for dvds?,paste or machine.A couple of the discs are very badly scratched.
Results 1 to 9 of 9
I have a Mad Katz scratch remover. Looks like a cd walkman, but has buffer heads instead of an optical setup. Uses one set of buffer heads to basically grind off a layer of plastic(obviously very small), then you replace the heads with a polishing ones that smooth it all out. Works well on aggressive scratches.
thanks,yes ive seen one of these,wasnt sure if it was any good.the scratches are quite heavy on the dvds,i just want to recover the data ,not bothered about saving the discs.At the moment there completely unplayable.
I cant the dvds are so badly scratched that the drive cant read them.
Try Fellowes CD/DVD Scratch Repair Kit. They should be available at OfficeMax and maybe at other places as well. It uses some chemical-soaked cloths that soften up disc plastic just enough to rub out scratches. It may require some hard rubbing on deep scratches, but it works better than anything else I've tried.
The fellowes kit is only for minor marks but the madkatz kit will remove deep scratches.
Yes, the Fellowes kit is claimed to work only for "minor" scratches. But it will work with deeper scratches as well if you rub hard enough. Still better than those Skip Doctor things and various polishes.
This is an excellent machine.
I have fixed hundreds of scratched discs, without a hitch.
www.simotech.com.tw
Got it from a place in California that sells them.
How to make a Karaoke DVD from scratch?
By MadeInBrazil in forum Authoring (DVD)Replies: 3Last Post: 15th Dec 2010, 13:06 -
Movie DVD with bad scratch
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 26th Jul 2010, 14:25 -
Is there any way to force rip a scratch dvd?
By tendra in forum Authoring (DVD)Replies: 13Last Post: 26th Jul 2009, 20:46 -
Fix It Scratch Remover
By VideoLearnerGuy in forum Off topicReplies: 5Last Post: 29th Nov 2007, 08:31 -
Best macrovision remover for standalone dvd - recorders
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 41Last Post: 23rd Nov 2007, 16:22
