Closed Thread
Results 1 to 11 of 11
    Jan 2006
    Okay..i made a boo boo...
    I burned Bambi II and the audio is off my 5 seconds....is there a way to fix this after i've converted to VOB? In other words, the avi file no longer exists rather, i now have the DVD at 5 seconds off.....
    Thanks!
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Do you actually own the original DVD? It seems from your post you dont.
    Jan 2006
    It's my neighbor's friends copy of an AVI file of Bambi II? Is there a problem with copy a friends friends AVI's?
  4. There is if you are creating a DVD for yourself and do not own the original.
    Jan 2006
    ..rather is there something wrong with me copying a friends friends avi?
  6. Yes. You haven't purchased an original therefore you effectively have no license to keep a backup.
  7. Ists just as illegal as downloading a movie from the internet.
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    There is when it's not even availible to purchase yet 8)
    IE: WAREZ
    Jan 2006
    oooh...my bad then. sorry...should i just shut the heck up now?
    thanks for the heads up though.
    am burning and breaking the cd into million pieces as I type this...thanks
  10. Yes, this topic has been reported by a fellow member.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    buy the dvd.
