    Jan 2006
    I was wondering how to make a little intro clip on a dvd before the menu is shown. And Does DVDLab support that?
  2. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Check this thread out
    https://forum.videohelp.com/viewtopic.php?t=287694&highlight=
    specifically,
    Originally Posted by manono
    This can be done quite easily using a combination of TDA and PGCEdit. First, author without the intro clip. Open the newly authored DVD in PGCEdit. Up at the top go Title->Import First Play (Startup) Clip, and follow the short instructions from there.
    and this thread for some nitty & gritty details:
    https://forum.videohelp.com/viewtopic.php?t=289269&highlight=
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Lab - First Play. Just drag a connection from first play to your video intro, then from the intro to the first menu. Honestly - how hard is it to read the manual or look at the mediachance tutorials ?
    Read my blog here.
  4. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    I'd like to say that: Sony DVD Archtiect can also do it for you. Select the intro for the DVD and that's all (prepare and burn your DVD) :@)
