    Aug 2004
    Mexico
    Hi! Good day!
    Here's my problem. I have few videos that i want to burn, but I want to make an "aspect ratio conversion". Here's the example:
    I want to go from this (4:3)
    to this (16:9)
    is there any way to remove the black bars so I can make a "widescreen" video? and what program should I use for this?.... THANKS in advance for the tips
    Feb 2003
    Calgary, AB Canada
    you can crop with d-vision or ffmpegX.
    visit my photo retouching website: http://www.shiftstudio.ca
    Aug 2004
    Mexico
    thanks man!!!! :P
  4. Is this of any help:
    How can I convert 4:3<->16:9 with or without letterboxing (and preserve interlacing):
    http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.html#43-169
    Feb 2003
    Calgary, AB Canada
    I should mention that cropping (and possibly scaling) requires re-encoding (and theoretical quality loss).
    Also I'm not sure what type of video your source is, or what the desired output is - but you will do things differenly depending on this.
