I am using AVS capture to capture video.With avermedia ezdvdmaker usb edition.I get this error that says List index of bounds(-1).I can record and the video looks good but the sound is not syncing with the video.The audio is ahead of the video.
Guess would be to start by contacting avermedia about the error, determining if your PC will work with it and so on.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Promblems using dvd flick
By willcuk22 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 06:10 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
