Ave,
I installed the latest stable binaries of the reallib package in my /Library/Application Support/ffmpegx and opened a .rm file in ffmpegx to convert it to avi. This is what i'm getting:
Help!
Mickey
Results 1 to 10 of 10
I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it!
Check if ffmpegX is in /Applications and not another folder, check if your hard disk does not have any spaces or accented or special characters in the name.
Ave,Originally Posted by major
I do have FFMPEGX in another folder, not the applications folder. Will it work if i just copy the FFMPEGX application in the /Applications folder or do i need to re-install it in the /Applications folder?
Also, the name of my hard disk is "Macintosh HD" ... the default name. It has a space in it!
MickeyI don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
Redownloaded FFMPEGX and copied it to /Applications folder.
Renamed Hard Disk to "Macintosh_HD".
Loaded the real media file in FFMPEGX, still the same result. Exactly like the screenshot above.
Just wanted to confirm. The latest stable release that i download for the reallib package, the reallib folder contains 47 files. Is that correct?
Mickey.I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
.ram normally being metafiles, with no a/v, I'd be surprised if you could encode like this. I would think you'd need the ra/rm/rmvb file that the ram file points to. Try opening the ram file in a text editor to read the true location of the RealMedia data.
I would keep /Library/ free of files you create/play/modify, as it is essentially for Mac OS and applications. Could be harmless, but it seems like a bad idea to keep personal files there.
Ave,Originally Posted by Case
I know what you're saying abou the .ram files, but this one is actually a 24 MB file and it plays perfectly fine in Real Player. I don' think it's streaming media from any location. I did open it in a text editor and as expected, only found tons of Gibberish.
I agree, not a good idea to keep personal files in /Library ... but it's not the cause of this particular problem.
Still looking for solution.
Thanks,
ffmpegX can both open .ram metafiles and .rm video files. However, if your file is a video file, then it must be named .rm and not .ram, or ffmpegX will think it is a metafile and will use random video data as a pointer to the actual file.
Reallib package installation doesn't work for me
By caixiaoeva in forum ffmpegX general discussionReplies: 18Last Post: 30th Oct 2010, 15:20 -
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 09:45 -
Converting Real Media
By KLouis22 in forum Video ConversionReplies: 2Last Post: 29th May 2009, 16:47 -
real media to avi help
By odiedog in forum Video ConversionReplies: 5Last Post: 18th Jan 2009, 05:10 -
Latest OS X reallib binaries?
By Scallywag in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jun 2007, 17:26
