MAC OSX 10.3.9 / Toast Titanium v.6 / ffmpegX 0.0.9u
newbie mac burning question
Hi I have a bunch of .mpg files that I'm trying to put onto one CD using toast 6 - I dropped the mpg onto ffmpegX to see what type it was and it shows as
mpeg-2 480x576, 2350kbps, 25fps
audio mp2,44100hz 192 kpbs
First Q: is there a utility such as Gspot but for the Mac that performs a similar function in identyfying codecs etc? or is ffmepgx the best way to identify frame rates / codecs etc
Second - when I select info from ffmpegX it says "alert" and nothing else?
I then tried dropping the mpgs into Toast 6 to create a DVD - I have the options video - pal - and the quality changed to svcd to allow me to squeeze more episodes onto a DVD - i am recording onto a standard DVD-R
When I try to record Toast gives me the message
CDROM XA or Audio tracks cannot be written to DVD
same problem if i choose VCD instead of SVCD
Any ideas as to the quickest way to resolve this? do I need to run it through ffmpegX to change the audio in some way, or is it something simple I'm overlooking??
Or is there a way to change a bunch of .mpg files into one VIDEO_TS folder I can then give to Toast?
I checked all the guides but nothing seems obvious, apologies if I overlooked something.
Thx in advance
CD, further down DVD, be precise please.Originally Posted by spigfry
Looks like a regular SVCD compliant PAL mpeg file. One other thing you will always want to know about a video file is duration.Originally Posted by spigfry
VCD and SVCD are meant to be written to CD-R. The way the (S)VCD data is written to disc is incompatible with DVD discs. That way is called Mode2 Form2, which requires a CD-ROM XA structure.Originally Posted by spigfry
ffmpegX has a svcdvd tool that will create a DVD from SVCD mpegs, without re-encoding the video (thus fairly fast). One thing to note is that the SVCD video frame size is outside the DVD spec, so some stand-alone DVD players will not play these SVCD-on-DVD dics properly.Originally Posted by spigfry
Burning AVI Files in Toast 7
By Luckyword in forum MacReplies: 9Last Post: 16th Jul 2010, 13:05 -
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 23:18 -
Looking to convert scr files (screensaver slideshows) to avi or mpg format
By wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 18:28 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 18:36 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
